I'm trying to cross-compile an autotools project (UCX), and I'm getting an error on a missing librt.so (part of the libc package):
Command: CC=armclang.exe CFLAGS='--target=aarch64-arm-none-eabi' ./configure --host=arm-linux
Error:
configure:21777: checking for shm_open in -lrtconfigure:21802: /.../compile armclang.exe -o conftest --target=aarch64-arm-none-eabi conftest.c -lrt >&5Fatal error: L6450U: Cannot find library rt.Finished: 0 information, 0 warning, 0 error and 1 fatal error messages.armclang: error: linker command failed with exit code 1 (use -v to see invocation)configure:21802: $? = 1configure: failed program was:| /* confdefs.h */| #define PACKAGE_NAME "ucx"| #define PACKAGE_TARNAME "ucx"| #define PACKAGE_VERSION "1.7"| #define PACKAGE_STRING "ucx 1.7"| #define PACKAGE_BUGREPORT ""| #define PACKAGE_URL ""| #define STDC_HEADERS 1| #define HAVE_STDLIB_H 1| #define HAVE_STRING_H 1| #define HAVE_INTTYPES_H 1| #define HAVE_STDINT_H 1| #define __EXTENSIONS__ 1| #define _ALL_SOURCE 1| #define _GNU_SOURCE 1| #define _POSIX_PTHREAD_SEMANTICS 1| #define _TANDEM_SOURCE 1| #define PACKAGE "ucx"| #define VERSION "1.7"| #define LT_OBJDIR ".libs/"| #define STDC_HEADERS 1| #define restrict __restrict| #define HAVE_DECL_STRERROR_R 0| #define UCX_CONFIGURE_FLAGS "--enable-optimizations --disable-logging --disable-debug --disable-assertions --disable-params-check --host=arm-linux| #define UCX_MODULE_SUBDIR "ucx"| #define UCX_ALLOC_ALIGN 16| #define HAVE_ATTRIBUTE_NOOPTIMIZE 0| /* end confdefs.h. */|| /* Override any GCC internal prototype to avoid an error.| Use char because int might match the return type of a GCC| builtin and then its argument prototype would still apply. */| #ifdef __cplusplus| extern "C"| #endif| char shm_open ();| int| main ()| {| return shm_open ();| ;| return 0;| }configure:21811: result: noconfigure:21821: error: librt not found
Should I build librt from source, or is there some pre-built ARM-targeted replacement?
Any other tips for the command-line?
