When I install GNU Arm Embedded Toolchain Version 7-2018-q2-update and then try to run arm-none-eabi-gdb.exe I get an error message that says:
---------------------------arm-none-eabi-gdb.exe - System Error---------------------------The code execution cannot proceed because libwinpthread-1.dll was not found. Reinstalling the program may fix this problem. ---------------------------OK ---------------------------
Here is the page where I downloaded it from:
https://developer.arm.com/open-source/gnu-toolchain/gnu-rm/downloads
Hi Bill,
Could you have a look at this post to see if that helps?
https://stackoverflow.com/questions/28907304/cc1-exe-system-error-libwinpthread-1-dll-missing-but-it-isnt
regards,
Joseph
