I'd like to generate assembly file for a corresponding .c file and I've tried the following which do not work.
armcc.exe -c test.c -o test.o fromelf.exe -c test.o -o test.s
The above generates test.s but it does not have assembly code for any of the functions defined in the test.c file. I'm looking something similar to
objdump -d test.o
Environment
You want the assembler in a format that you can pass to armasm? If so, try the "--asm" flag on armcc:
armcc -c --asm test.c armasm test.s
Armcc will produce a .s file, and armasm will produce a .o file
Thank you, but still the .s file here is not something I'm looking for. So for example, for the following dummy 'C' code
#include <stdio.h> #include <stdint.h> typedef struct data_t { uint32_t a; uint16_t b; } data_t; static void WriteS32(uint32_t x, uint32_t y) { data_t testdata; testdata.a = x; testdata.b = y; } static void ReadS32(data_t emp) { uint32_t x = emp.a; uint32_t y = emp.b; }
I, get the following .s file
; generated by Component: ARM Compiler 5.06 update 6 (build 750) Tool: armcc [4d3637]; commandline armcc [-c --asm test.c] THUMB PRESERVE8
AREA ||.arm_vfe_header||, DATA, READONLY, NOALLOC, ALIGN=2
DCD 0x00000000
IMPORT ||Lib$$Request$$armlib|| [CODE,WEAK]
ATTR FILESCOPE ATTR SETVALUE Tag_ABI_PCS_wchar_t,2 ATTR SETVALUE Tag_ABI_enum_size,1 ATTR SETVALUE Tag_ABI_optimization_goals,3 ATTR SETVALUE AV,18,1
ASSERT {ENDIAN} = "little" ASSERT {INTER} = {FALSE} ASSERT {ROPI} = {FALSE} ASSERT {RWPI} = {FALSE} ASSERT {IEEE_FULL} = {FALSE} ASSERT {IEEE_PART} = {FALSE} ASSERT {IEEE_JAVA} = {FALSE} END
However, when I try a similar thing with the gcc and objdump on a x86_64 Linux based system, i get the following code:
$ gcc -c test.c -o test.o $ objdump -d test.o test.o: file format elf64-x86-64 Disassembly of section .text: 0000000000000000 <WriteS32>: 0: 55 push %rbp 1: 48 89 e5 mov %rsp,%rbp 4: 89 7d ec mov %edi,-0x14(%rbp) 7: 89 75 e8 mov %esi,-0x18(%rbp) a: 8b 45 ec mov -0x14(%rbp),%eax d: 89 45 f0 mov %eax,-0x10(%rbp) 10: 8b 45 e8 mov -0x18(%rbp),%eax 13: 66 89 45 f4 mov %ax,-0xc(%rbp) 17: 90 nop 18: 5d pop %rbp 19: c3 retq 000000000000001a <ReadS32>: 1a: 55 push %rbp 1b: 48 89 e5 mov %rsp,%rbp 1e: 48 89 7d e0 mov %rdi,-0x20(%rbp) 22: 8b 45 e0 mov -0x20(%rbp),%eax 25: 89 45 f8 mov %eax,-0x8(%rbp) 28: 0f b7 45 e4 movzwl -0x1c(%rbp),%eax 2c: 0f b7 c0 movzwl %ax,%eax 2f: 89 45 fc mov %eax,-0x4(%rbp) 32: 90 nop 33: 5d pop %rbp 34: c3 retq
I need something similar with ARMCC and probably with use of fromelf
Ah, ok - I misunderstood what sort of output you wanted to see. Yes, fromelf will is the tool you want and it is the "-c" flag that gives you disassembly output.
I think the problem for your test case is that compiler is being clever. It's detected that the two functions are static and not referenced, and has performed redundant code elimination. As a result you end up with an empty file. It's something I've hit when creating small test cases before, the compiler optimizes code away if it doesn't do anything.
For your test, a couple of tweaks should stop the compiler optimizing everything out. Removing static from the function definitions gives:
** Section #1 '.text' (SHT_PROGBITS) [SHF_ALLOC + SHF_EXECINSTR] Size : 8 bytes (alignment 4) Address: 0x00000000 $a .text WriteS32 0x00000000: e12fff1e ../. BX lr ReadS32 0x00000004: e12fff1e ../. BX lr
So now the functions are there. But the compiler has still worked out that the code is ultimately "redundant" and made reduced them to stubs.
Modifying the functions to reference a global structure, rather than a local one, and having the read function return something:
** Section #1 '.text' (SHT_PROGBITS) [SHF_ALLOC + SHF_EXECINSTR] Size : 40 bytes (alignment 4) Address: 0x00000000 $a .text WriteS32 0x00000000: e59f201c . .. LDR r2,[pc,#28] ; [0x24] = 0 0x00000004: e5820000 .... STR r0,[r2,#0] 0x00000008: e1c210b4 .... STRH r1,[r2,#4] 0x0000000c: e12fff1e ../. BX lr ReadS32 0x00000010: e92d4003 .@-. PUSH {r0,r1,lr} 0x00000014: e1dd00b4 .... LDRH r0,[sp,#4] 0x00000018: e59d1000 .... LDR r1,[sp,#0] 0x0000001c: e0800001 .... ADD r0,r0,r1 0x00000020: e8bd800c .... POP {r2,r3,pc} $d 0x00000024: 00000000 .... DCD 0
thanks a ton :)
If you have a c file to compile isn't it all together the other way around to first get to the elf and then disassemble it. Why don't you in the compilation give "--save-temps" and you will have intermediate files throughout the compilation stored.
armcc --save-temps test.c -o test
$ armcc.exe --help Product: ARM Compiler 5.06 Component: ARM Compiler 5.06 update 6 (build 750) Tool: armcc [4d3637] $ armcc.exe --save-temps test.c -o test Fatal error: C3900U: Unrecognized option '--save-temps'.
Seems the armcc version that I have does not have such a flag.
Okey. Probably my bad. I''m using Linaro GCC toolchain https://www.linaro.org/downloads/
It is possible that only GCC has it. Look through your toolchain if it has one (or similar).
Thanks for this information
Thank youuu
