"mov" vs "adds ... #0" (cortex M0)
I've noticed that arm gcc, when compiling code for Cortex-M0 (at least) seems to generate instructions:
   adds r0, r2, #0
Where I'm pretty sure that it the same as:
   movs r0, r2
In fact, I can disassemble a relatively substantial program and not find a single register/register "mov" or "movs" instruction (for r0..r7)
is there some reason for this?
  • MOVS r0, r2 is the same as LSLS r0, r2, 0 according to UAL syntax.
    ADDS with zero was emitted by early Thumb-1 compilers, so GCC should ideally be updated as it makes disassembly harder to read.
    Note it's generally best to report issues like this in the GCC bugzilla
    Wilco
