D:\Builds\temp>armcc -o tmp.o -c tmp.c --no_debug"tmp.c", line 6: Warning: #1-D: last line of file ends without a newline } ^tmp.c: 1 warning, 0 errors
D:\Builds\temp>objdump --full-contents --section=.comment tmp.otmp.o: file format elf32-littleContents of section .comment: 0000 41524d2f 5468756d 6220432f 432b2b20 ARM/Thumb C/C++ 0010 436f6d70 696c6572 2c205256 4354322e Compiler, RVCT2. 0020 32205b42 75696c64 20353933 5d006172 2 [Build 593].ar 0030 6d636320 2d2d6661 73746c69 63656e73 mcc --fastlicens 0040 65202d2d 73697465 6c696365 6e736520 e --sitelicense 0050 2d63202d 6f746d70 2e6f2074 6d702e63 -c -otmp.o tmp.c 0060 00 .
Or as you have RVCT, you can use fromelf.
[color=#222222][size=2]I think Strip tool doesn't support the ARM obj files .Also confirmed by running it.
so looking for option at compile time.
