Android - Streamline fails to capture
I am trying to use Streamline for Android performance measurements on a Hikey960 Board. License setup and device registration worked. When clicking "Start capture" I get the following Error:
Problem occured
License map could not route the specified feature: "Streamline.64Bit.BasicCounters"
Used Version: Arm Streamline Performance Analyzer Version 6.5.1, Build 20180103_121655
Is there a known workaround for this problem?
Best regards
  • Which DS-5 edition are you using (Community, Professional, Ultimate,  etc...)?
    Arm 64-bit architecture (Armv8-A) support is only available with DS-5 Ultimate edition.  If you have DS-5 Ultimate edition installed, you will need to make sure that DS-5 using an "DS-5 Ultimate Edition" license by opening Eclipse of DS-5 and going to "Help" -> "Arm License Manager..." -> "Select the toolkit that you intend to use:" -> "DS-5 Ultimate Edition".
  • This answers my question, thank you. I am using the Community version. I was misled by the line:
    Arm DS-5 Community Edition includes:
    DS-5 Debugger for bare-metal development with Armv8-A Foundation Model.
