i am running the DS5 Community Edition under Ubuntu 16.04 64bit and wanted to work with the Armv8-A Base Platform FVP for my Diploma. Addind a new Model Database and i launch the Model it works fine but While Importing the Models as showed in the Guide an Error is shown: CDB Import Error MODEL IMPORT ERROR.
I Cannot find anything about it. The Path Variables to the Model and DS 5 are set.
Same Error comes when i try to use the Armv8-A Foundation Platform
Thanks for any Help in Advance
eclipse.buildId=4.6.3.M20170301-0400 java.version=1.8.0_45 java.vendor=Oracle Corporation BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US Framework arguments: -product com.arm.ds.ce Command-line arguments: -os linux -ws gtk -arch x86_64 -product com.arm.ds.ce com.arm.debug.configdatabase.modelconfig.gui Error Thu Jan 11 14:50:02 CET 2018 CDB Import Error MODEL IMPORT ERROR com.arm.pce.exceptions.ModelImportException: MODEL IMPORT ERROR at com.arm.pce.importer.ImportController.importModelFromFile(ImportController.java:382) at com.arm.pce.importer.ImportController.doModelImport(ImportController.java:225) at com.arm.pce.importer.ImportController.doImport(ImportController.java:190) at com.arm.debug.configdatabase.modelconfig.gui.pceditor.CdbImportProgress.run(CdbImportProgress.java:128) at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:437) at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:353) at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:481) at com.arm.debug.configdatabase.modelconfig.gui.pceditor.PlatformConfigEditPart.performImport(PlatformConfigEditPart.java:3325) at com.arm.debug.configdatabase.modelconfig.gui.pceditor.PlatformConfigEditPart.access$6(PlatformConfigEditPart.java:3319) at com.arm.debug.configdatabase.modelconfig.gui.pceditor.PlatformConfigEditPart$2.widgetSelected(PlatformConfigEditPart.java:418) at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249) at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84) at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5227) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1340) at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4561) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4151) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022) at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150) at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148) at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:497) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610) at org.eclipse.equinox.launcher.Main.run(Main.java:1519) at com.arm.workbench.Hook.run(Hook.java:487) Caused by: java.lang.NullPointerException at javax.xml.transform.stream.StreamSource.<init>(StreamSource.java:147) at javax.xml.validation.SchemaFactory.newSchema(SchemaFactory.java:654) at com.arm.pce.dstream.impl.ModelDescFileParser.validateAgainstSchema(ModelDescFileParser.java:77) at com.arm.pce.dstream.impl.ModelDescFileParser.<init>(ModelDescFileParser.java:63) at com.arm.pce.importer.ImportController.importModelFromFile(ImportController.java:329) ... 37 more
Hello - thank you for downloading DS-5 Community Edition. This is a limited version of the full DS-5 toolchain, and as such, certain features are unavailable. This includes the ability to create configurations of new targets, which is what you are trying to do here.
That being said, there is no need for you to do this... these configurations are already provided with the tool. Go to the (Window -> Perspective -> Open Perspective ->) DS-5 Debug Perspective, then go to the Debug Control pane. Right-click therein, and select Debug Configurations, and you will see the available targets listed (as below).
