Hi,I find OpenCL mode in ARM DS-5 Streamline user guide, but can't get it when using it. I am using DS-5 5.27.1 and r7p0 driver.The user guide says "To enable OpenCL mode, you must create an instrumentation configuration file. For details of the options it must contain, see the documentation that is supplied with the ARM Driver Development Kit (DDK) for Mali Midgard devices."
How can i get the documents and is there any more descriptions about this?thanks.
Hi Xinkuokuo,Could you tell me a bit more about your situation so I can help you in the best way I can? Feel free private message me if it is easier.You mention that you are using R7P0 of the driver. Which Mali core are you using? Where did you get the version of the driver from? What platform are you targetting?Which version of DS-5 are you currently using?Hope this helps,Stephen
