DS-5 Errors running builder 'CDT Builder' on project (java.lang.NullPointerException)
If I set Project properties >> C/C++ Build >> Settings >> Tool Settings >> ARM Linker >> Image Layout >> Scatter File to an absolute path, I can build the project successfully.
If I set to a relative path, using the variable PROJECT_LOC (for example <PROJECT_LOC\..\..\..\..\..\..\>), the build fails with the message
This seems the same issue described here.
Is there a way to fix this error?
  • Hi, are you using directly PROJECT_LOC or ${PROJECT_LOC} ?
    Personnally I used to defined an environnment variable MyWorkDir and use a path relative to this variable, and it is ok.
    regards
    claudio
  • I used PROJECT_LOC directly and this doesn&#x27;t work, with the error described in my first message.
    If I use ${PROJECT_LOC} I get a different error:
    L6031U: Could not open scatter description file \..\..\..\..\..\..\platform\devices\VF6XX\linker\arm\scatter_m4.scat: No such file or directory
  • Hi,
    So it seems to be a better error :-)
    I mean 1st one looks like there is a syntax error. The 2nd one just say the environment variable can be resolved, but the path is not correct.
    did you try with &#x27;/&#x27; instead of &#x27;\&#x27;. ?
    claudio
  • I replaced all the backslash chars "\" with slashes "/" but this doesn't work.
    Looking to other flags set for ARM Assembler, I tried
    ${ProjDirPath}/../../../../../../platform/devices/VF6XX/linker/arm/scatter_m4.scat
    and this works.
