how to set fixed address for variables/functions  at compiling stage in ADS?
Note: This was originally posted on 18th September 2009 at http://forums.arm.com
in ads 1.2, I set fixed address for a variable like this:
int    file_len  __attribute__((_at_(0x16000))) = 0;
but compile error, how can i do?
thank you very much!
  • Note: This was originally posted on 18th September 2009 at http://forums.arm.com
    You can use this but you have to set the initial value manually...
    #define file_len   (*(int *)(0x00016000))
    -----ohh,thanks.
    But in my program, I need "file_len" located at 0x00016000 and occupy 4bytes memory,
    how can I do?
    best regards,
    You can do this directly using linker tricks, but it's not really designed for placement of individual variables.
    If you really need this, I'd suggested storing a pointer to the location rather than the value itself:
    static int * const pFileLen = (int *)(0x00016000);
    /* Store value. */
    *pFileLen = uiMyValue;
    /* Get value. */
    uiMyValue = *pFileLen;
  • Note: This was originally posted on 13th November 2009 at http://forums.arm.com
    Can Any body tell me how to place a function at specified location in RVDS? __at__ has got limitations. I don't want to change my linker file hence i am looking for trick or hack in code.
    On second thought, this address is most likely in the on-chip NV (flash) memory region...
    So , you can NOT have a variable at this particular address. Maybe the compiler was
    trying to tell you this simple fact :-) What error does compiler give you anyway ?
