I have created a Hex file using keil and loaded the file using load flash in PROGISP. I have used Ultra 8051 development kit , AT89S52 .But the output is not obtained.We are assuming that the Hex file we generated with a different code is not the same as the sample given Hex file. So please let me know about the Hex file format and where the problem and the solution.
Thanks and Regards,
Naga Radhika.
Hi radhika, and welcome to the Community!
I have moved your question to Software Development Tools where someone may be able to help. If not, you could try the Keil forums for more specialist help.
