I've downloaded and installed ds-5 eclipse from arm web site related to vybrid starter kit. When I try to enter activation code from that web site license manager fails with "unable to execute query" message at the end activation process. Could someone explain me where i do activation wrong?
I've just looked throught eclispe error logs and found that server generate error for api call
!ENTRY com.arm.eclipse.users 4 150 2016-01-14 17:29:23.683
!MESSAGE Unable to execute API call, url = https://ds.arm.com/api/v1/connect?format=json, query = null
!STACK 0
com.arm.webapis.client.ResponseError: The server generated an error for the 'https://ds.arm.com/api/v1/connect?format=json'
It seems very odd for me.
Hi, We are investigating this issue. We will update you as soon as we have more information. Sorry for the trouble. Regards Ashok
We believe this issue has been fixed on our side. Can you please retry and let us know if the problem has been resolved.
Hello, Ashok
Thank you so much for help, but Eclipse DS-5 is still failing to create a license with the same error in logs.
