streamline is not working
My Computer is Windows 7 ( 32 bit ) and download DS-5 V5.32 for Window 32bit
After Install, execute Streamline but it dose not work.
Here is log message in DS-5 v5.23.0/sw/streamline/configuration/time.log
How can i solve this problem?
!SESSION 2015-12-02 13:54:21.137 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_45
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=ko_KR
Command-line arguments:  -os win32 -ws win32 -arch x86 -data @user.home/AppData/Local/streamline
!ENTRY org.eclipse.osgi 4 0 2015-12-02 13:54:23.047
!MESSAGE An error occurred while automatically activating bundle org.eclipse.ui.workbench (427).
!STACK 0
org.osgi.framework.BundleException: Error starting module.
at org.eclipse.osgi.container.Module.doStart(Module.java:580)
at org.eclipse.osgi.container.Module.start(Module.java:439)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:531)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:320)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:345)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:337)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:568)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:191)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/swt/SWTError
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:2671)
at java.lang.Class.getConstructor0(Class.java:3075)
at java.lang.Class.newInstance(Class.java:412)
at org.eclipse.osgi.internal.framework.BundleContextImpl.loadBundleActivator(BundleContextImpl.java:755)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:706)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:936)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:319)
at org.eclipse.osgi.container.Module.doStart(Module.java:571)
... 28 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.swt.SWTError cannot be found by org.eclipse.ui.workbench_3.106.2.v20150204-1030
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:432)
... 37 more
Root exception:
... 37 more
!ENTRY org.eclipse.osgi 2 0 2015-12-02 13:54:23.047
!STACK 0
java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.ui.workbench (427).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:116)
Caused by: org.osgi.framework.BundleException: Error starting module.
... 25 more
... 28 more
... 37 more
!ENTRY org.eclipse.core.filesystem.linux.x86_64 2 0 2015-12-02 13:54:23.063
!MESSAGE Could not resolve module: org.eclipse.core.filesystem.linux.x86_64 [270]
  Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.os=linux) (osgi.arch=x86_64))"
!ENTRY org.eclipse.core.filesystem.macosx.nl_ja 2 0 2015-12-02 13:54:23.063
!MESSAGE Could not resolve module: org.eclipse.core.filesystem.macosx.nl_ja [272]
  Unresolved requirement: Require-Capability: eclipse.platform; filter:="(osgi.os=macosx)"
!ENTRY org.eclipse.e4.ui.workbench.renderers.swt.cocoa 2 0 2015-12-02 13:54:23.063
!MESSAGE Could not resolve module: org.eclipse.e4.ui.workbench.renderers.swt.cocoa [315]
  Unresolved requirement: Require-Capability: eclipse.platform; filter:="(osgi.ws=cocoa)"
!ENTRY org.eclipse.e4.ui.workbench.renderers.swt.cocoa.nl_ja 2 0 2015-12-02 13:54:23.063
!MESSAGE Could not resolve module: org.eclipse.e4.ui.workbench.renderers.swt.cocoa.nl_ja [316]
!ENTRY org.eclipse.core.filesystem.win32.x86_64.nl_ja 2 0 2015-12-02 13:54:23.063
!MESSAGE Could not resolve module: org.eclipse.core.filesystem.win32.x86_64.nl_ja [274]
  Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.os=win32) (osgi.arch=x86_64))"
!ENTRY org.eclipse.swt.gtk.linux.x86_64.nl_ja 2 0 2015-12-02 13:54:23.063
!MESSAGE Could not resolve module: org.eclipse.swt.gtk.linux.x86_64.nl_ja [388]
  Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.ws=gtk) (osgi.os=linux) (osgi.arch=x86_64))"
!ENTRY org.eclipse.swt.gtk.linux.x86_64 2 0 2015-12-02 13:54:23.063
!MESSAGE Could not resolve module: org.eclipse.swt.gtk.linux.x86_64 [390]
!ENTRY org.eclipse.swt.cocoa.macosx.x86_64.nl_ja 2 0 2015-12-02 13:54:23.063
!MESSAGE Could not resolve module: org.eclipse.swt.cocoa.macosx.x86_64.nl_ja [387]
  Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.ws=cocoa) (osgi.os=macosx) (osgi.arch=x86_64))"
!ENTRY org.eclipse.swt.win32.win32.x86_64 2 0 2015-12-02 13:54:23.063
!MESSAGE Could not resolve module: org.eclipse.swt.win32.win32.x86_64 [394]
  Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.ws=win32) (osgi.os=win32) (osgi.arch=x86_64))"
!ENTRY org.eclipse.ui.cocoa 2 0 2015-12-02 13:54:23.063
!MESSAGE Could not resolve module: org.eclipse.ui.cocoa [402]
!ENTRY org.eclipse.core.filesystem.linux.x86_64.nl_ja 2 0 2015-12-02 13:54:23.078
!MESSAGE Could not resolve module: org.eclipse.core.filesystem.linux.x86_64.nl_ja [268]
!ENTRY org.eclipse.ui.cocoa.nl_ja 2 0 2015-12-02 13:54:23.078
!MESSAGE Could not resolve module: org.eclipse.ui.cocoa.nl_ja [403]
!ENTRY org.eclipse.equinox.security.win32.x86_64 2 0 2015-12-02 13:54:23.078
!MESSAGE Could not resolve module: org.eclipse.equinox.security.win32.x86_64 [351]
!ENTRY org.eclipse.swt.cocoa.macosx.x86_64 2 0 2015-12-02 13:54:23.078
!MESSAGE Could not resolve module: org.eclipse.swt.cocoa.macosx.x86_64 [386]
  Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.ws=cocoa) (osgi.os=macosx) (osgi.arch=x86_64) )"
!ENTRY org.eclipse.core.filesystem.macosx 2 0 2015-12-02 13:54:23.078
!MESSAGE Could not resolve module: org.eclipse.core.filesystem.macosx [271]
  Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.os=macosx) (|(osgi.arch=x86) (osgi.arch=ppc) (osgi.arch=x86_64)))"
!ENTRY org.eclipse.core.resources.win32.x86_64 2 0 2015-12-02 13:54:23.078
!MESSAGE Could not resolve module: org.eclipse.core.resources.win32.x86_64 [283]
!ENTRY org.eclipse.core.filesystem.win32.x86_64 2 0 2015-12-02 13:54:23.078
!MESSAGE Could not resolve module: org.eclipse.core.filesystem.win32.x86_64 [276]
!ENTRY org.eclipse.core.filesystem.linux.x86.nl_ja 2 0 2015-12-02 13:54:23.078
!MESSAGE Could not resolve module: org.eclipse.core.filesystem.linux.x86.nl_ja [269]
  Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.os=linux) (osgi.arch=x86))"
!ENTRY org.eclipse.swt.win32.win32.x86_64.nl_ja 2 0 2015-12-02 13:54:23.078
!MESSAGE Could not resolve module: org.eclipse.swt.win32.win32.x86_64.nl_ja [392]
!ENTRY org.eclipse.equinox.security.macosx 2 0 2015-12-02 13:54:23.078
!MESSAGE Could not resolve module: org.eclipse.equinox.security.macosx [349]
  Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.os=macosx) (|(osgi.arch=x86)(osgi.arch=x86_64)(osgi.arch=ppc)) )"
!ENTRY org.eclipse.swt.gtk.linux.x86.nl_ja 2 0 2015-12-02 13:54:23.094
!MESSAGE Could not resolve module: org.eclipse.swt.gtk.linux.x86.nl_ja [389]
  Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.ws=gtk) (osgi.os=linux) (osgi.arch=x86))"
!ENTRY org.eclipse.osgi 4 0 2015-12-02 13:54:23.094
!MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in com.arm.streamline was unable to load class com.arm.streamline.application.Streamline.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176)
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.ui.workbench (427).
... 15 more
... 25 more
... 28 more
... 37 more
  • It looks like there is something wrong with the Windows 32-bit installer. Until we correct this, you should be able to fix this by removing the following 3 files from DS-5 v5.23.0\sw\streamline\plugins :
    org.eclipse.swt.nl_ja_4.4.0.v20150804100819.jar
    org.eclipse.swt.win32.win32.x86.nl_ja_4.4.0.v20150804100819.jar
    org.eclipse.swt.win32.win32.x86_64.nl_ja_4.4.0.v20150804100819.jar
    and also the .eclipse folder that was created in your home directory.
    Once you've done this, you should be able to run Streamline.
  • This worked for me as well, but depending on your setup you may additionally need to delete the folders in DS-5 v5.23.0\sw\streamline\configuration (for example, org.eclipse.core.runtime). But be careful not to delete config.ini as it is needed.
  • I follow your comment ( remove 3 files ) then Streamline is run and I can capture device data. Thank you for your help.
