no FPU in memset
How can I tell the linker/compiler not to use memset/memcpy function which use FPU registers?
For example: SCIOPTA allows to limit the use of the FPU for certain tasks (to improve task-switching). Tasks without FPU may not use FPU registers. But the compiler/linker uses optimized versions of memset() which results in an exception.
I tried to compile C files with --fpu none, but this produces link-timer errors.
  • For ARM compiler you could try --no_allow_fpreg_for_nonfpdata
    See ARM Information Center
  • Hi Joseph,
    that'll be the option I was looking for. Only it does not work. At least not with 5.04.
    My compile options:
    CPUFLAGS = --cpu cortex-a8 --apcs=/interwork --thumb
    CFLAGS += $(CPUFLAGS) --debug --diag_suppress=550 --c99 --no_inline
    CFLAGS += --diag_suppress=9933
    CFLAGS += --no_allow_fpreg_for_nonfpdata
    My code uses memset(...,0,...). _memset() in the Library checks if the destination is dividable by 4 and then jumps to memset_w which uses FPU registers.
  • Hi,
    I guess the FP instructions is inside the C runtime library, not the compiler generated code. Is that correct?
    I guess the option --no_allow_fpreg_for_nonfpdata only affects the compiler and there isn’t a switch to force C runtime code to use a different behavior.
    Sorry that I don’t have a solution for you right now.
    Regards,
    Joseph
  • Hi,
    yes, it is the memset in the standard C library. Guess there should be a no_allow_fpreg_for_nonfpdata version of the library.
    (Btw. GCC does the same and tries to be "smart" )
    THX for your time.
  • I guess the FP instructions is inside the C runtime library, not the compiler generated code. Is that correct?
    Then the solution will be to use -no_allow_fpreg_for_nonfpdata while compiling the runtime library (if using GCC, that is).
    I use GCC myself, and when building my toolchain, one of the steps is to generate multiple libraries; one for each CPU type; for instance, there's no Cortex-M0 with FPU, thus it's not necessary to generate a runtime library with FPU support.
  • Could be a solution. But isn't.
    For one, GCC does not have that or similar option (at least 4.9.3 2014 Q4 from launchpad), nor does DS-5 (professional) come with library sources.
    And the problem is not no-FPU or FPU. The problem is, that the user decides where to use the FPU and where not.
    The armcc option says it all: FPU registers only for FPU operation.
    If I compile a C program with float operations, the compiler shall use of course the FPU if activated per command line.
    And of course mixing soft-FPU code and hard-FPU code is difficult and rather seldom. But why not? At least as long no higher functions like sin() is used.
    In my opinion, either the linker should be able to link FPU compiled files against a non-FPU library _or_ provide FPU clean standard libraries.
  • The linker should never be allowed to modify the library, which is linked. Thus you must link with the correct library; this is your responsibility.
    That means you will need a library, which contains code that does not use the FPU registers, if you don't want your code to use FPU registers.
    I've used GCC 4.9 for more than a year now, and I have multiple libraries for each Cortex-M architecture and ARM7TDMI.
    So I can choose whether or not I want to use the FPU registers on Cortex-M4 by supplying a switch on the command-line for GCC and for the linker.
    The linker will chose the correct library, depending on my command-line switches; eg. if I built a library using -mcpu=cortex-m4 and -mtune=cortex-m3, and the switches I provide for the linker is exactly that, then this library will be linked.
    I'm not sure whether launchpad's GCC is built this way these days; I think it was earlier.
    If you want to solve the problem here and now, you could write your own substitution for memset and memcpy. Make sure the link-order is correct, so your library will be searched first. One problem with using this solution is that you might not catch all the library functions, which are using FPU-registers right away.
  • Jens,
    I think you are missing the point.
    Of course, if I use the FPU I must expect that for example printf() uses FPU registers.
    But I do not expect that the compiler uses FPU registers for things like memset().
    Since parts of the software are allowed (=> RTOS configuration) to use the FPU and some not, I need the choice.
    Clearly, I cannot use printf() in a task which is not allowed to use the FPU. If so, it is _my_ fault.
    So what is needed is that the linker has an option to choose the right library or I need the choice to build my own runtime library and setting the -no_allow ... option. But as I wrote, no library sources in DS-5 installation (maybe I need the ultra license).
    Neither works in GCC and DS-5/MDK. I think IAR does a better job here.
  • I probably misunderstood the problem as you wrote.
    Is the memset code you're speaking about, generated on-the-fly ?
    Eg. GCC generates both memcpy and memset code, if the block to set/copy is less than four 32-bit words.
  • I know GCC does optimize short memset/memcpy and I had to fight this on PowerPC. But so far I had no problem with GCC and ARM.
    The problem is with DS-5/MDK and memset() is in the library.
  • PowerPC, Atari ... we have a lot in common.
    Unfortunately my only option is running GCC, so I know nothing about DS-5/MDK.
    If we're lucky, maybe sellis or johannesbauer will put in a word or two about this.
  • Hi,
    Are you explicitly calling memset function or compiler internally invokes it for various memory copy codes from one address to another.
    Regards,
    Techguyz
  • I use "memset", then the library function checks size and alignment and then calls a function memset_w which uses FPU registers to write 8bytes at once.
  • Hi,
    I'm afraid there's no easy way to avoid this with the ARM Compilation tools.  At link time, if any of the user code was built for VFP then by default armlink will choose a library that is allowed to use the VFP.  It is possible to override the linker's default choice, and force it to use a non-VFP library (see later), but that choice applies to the entire image, so that both your non-VFP and VFP-using functions will end up calling an inefficient non-VFP library.
    When compiling with "--cpu=Cortex-A8", the compiler assumes VFP and NEON are allowed.  To have better control over this, one solution is to compile your non-VFP using functions with "--fpu=SoftVFP", and the VFP-using functions with "--fpu=SoftVFP+VFPv3".  These are link-time compatible.  The linker will select the library functions that use floating point instructions but pass floating point parameters in core registers.  As floating point instructions are still used by the library, that might not be sufficient to achieve the your goal of running some tasks entirely in soft-floating point and some in hard-floating point.
    If all your code is compiled with either "--fpu=SoftVFP" or "--fpu=SoftVFP+VFPv3", the linker’s default choice of an "--fpu=SoftVFP+VFPv3" library can be overridden by adding the name of the soft floating point only library on the linker command line.  In this case no library functions will use hardware floating point, so this is context switch safe, although will not be high performance if your VFP-using code makes heavy use of library functions.  To find the software floating point library location, compile all files with "--fpu=SoftVFP" and use the linker option "--info=libraries" to list the libraries that the linker actually selected.
    The only other solution would be to build _two_ executables, one containing the VFP-using functions and VFP libraries, and the other containing the non-VFP-using functions and non-VFP libraries, then join the two executables together somehow.
  • The C libraries provided in  ARM Compiler 5.04 contains several variants of the memmove/memset routines, and the linker selects which variant
    to use according to the build attributes in the files being linked.  If a file included in the link has an attribute indicating that it uses FPU instructions then the linker takes that to mean it is OK to use the variants of memmove/memset which use FPU instructions.
    Obviosuly this does not work in your special case if your application could be using FPU instruction but only under special cirumstances.
    One way around this is to create your own copy of the C library and remove the variants of memmove/memset that use FPU instruction
    from the library.   Then the linker will have to use the non FPU variants of memmove/memset.
    Copy the version of the ARM C library that you are linking with (here I am assuming it is c_2.l, the library name convention used is documented at
    http://infocenter.arm.com/help/topic/com.arm.doc.dui0475j/chr1358938936497.html.Use the --info=libraries option to the linker to list the libraries your application is actually linking with):
         cp $ARMLIB/armlib/c_2.l c_2.l
    List all files in the library that containt the NEON variants of memmove/memset/etc (this step is just informative):
         armar -t c_2.l | grep rt_neon_mem
    Remove these files from your copy of your library
         armar -d c_2.l `armar -t c_2.l | grep rt_neon_mem`
    Now use this modified c_2.l library to link with your application;  the application should not longer be using versions of memmove/memset which contain FPU instructions.
