How to make section can be written
Hi alls,
I am going to make a scripts to execute automation test.
I am creating a memory map of the CPU.
In the CPU, there is reserved area. When using simulator and write data to it: "error: [PC=0x2ee2] Invalid memory write to address 0x4004a000" is shown and the code is stuck at the writing line.
when using actual device, the issue did not occur.
I think the issue may relate with my linker scripts but I do not find any solution.
Can anyone help me?
