I try to compile the TrustZone example provided by examples/Bare-metal_examples_ARMv7.zip in DS-5 v5.21.1(latest version) and then I get this
License checkout for feature compiler5 with version 5.0201503 has been denied by Flex back-end. Error code: -9
I have already viewed INFOCENTER but error code in that page is -7 while my error code is -9.
I am sure I get the license correctly added, and DS-5 has validated and accepted that license.
I am using an 30-day Ultimate Edition License(Evaluation), can it only be compiled with a formal Ultimate Edtion license or am I missing some configuration?
Thanks in advance.
If you are getting a -9 error code, try this FAQ:
Trouble shooting node-locked license issues
Thanks a lot, I forgot the fact that I had reinstalled my VMWare, but the Host id would change with the system? Sounds a little strange.
It's a while since I've used VMWare, but I seem to remember it changes the MAC address if you make a copy of the VM. I guess the rationale being that you might run both at once.
