example makefile modify related
 importing the startup_Cortex-A53x1 example supplied with Arm Development Studio.
add new folder in /src,
and modified the makefile in the top folder
APP_C_SRC := $(wildcard $(SRC_DIR)/*.c) \
                       $(wildcard $(SRC_DIR)/dirx/*.c)
APP_S_SRC := $(wildcard $(ASM_DIR)/*.S)
OBJ_FILES := $(APP_C_SRC:$(SRC_DIR)/%.c=$(OBJ_DIR)/%.o) \
                       $(APP_C_SRC:$(SRC_DIR)/dirx/%.c=$(OBJ_DIR)/%.o)
$(APP_S_SRC:$(ASM_DIR)/%.S=$(OBJ_DIR)/%.o)
DEP_FILES := $(OBJ_FILES:%=%.d)
but the compile output is the same with before:
12:25:54 **** Build of configuration Default for project startup_Armv8-Ax1_AC6_lab' ****
make all
mkdir obj
Compiling src/GICv3_gicd.c...
Compiling src/timer_interrupts.c...
Compiling src/sp804_timer.c...
Compiling src/main.c...
Compiling src/GICv3_gicr.c...
Compiling src/uart.c...
Compiling src/retarget.c...
Compiling asm/vectors.S...
Compiling asm/v8_aarch64.S...
Compiling asm/v8_utils.S...
Compiling asm/startup.S...
Linking startup_Armv8-Ax1_AC6.axf
Done.
12:25:56 Build Finished. 0 errors, 0 warnings. (took 2s.237ms)
is there anything more to notice?
  • Hi again
    Try this instead.  Into both makefiles for startup_Armv8-Ax1_AC6 and startup_Cortex-A53x1_AC6 add:
    EXT_C_SRC := $(wildcard $(SRC_DIR)/dirx/*.c)
                 $(EXT_C_SRC:$(SRC_DIR)/dirx/%.c=$(OBJ_DIR)/%.o) \
    and later add a compilation rule for the new folder, for startup_Armv8-Ax1_AC6:
    $(OBJ_DIR)/%.o : $(SRC_DIR)/dirx/%.c | $(OBJ_DIR)
        $(PROGRESS)
        $(QUIET) $(CC) -c $(TARGET_ARCH) $(CPPFLAGS) $(CFLAGS) -o $@ $<
    and (slightly different) for startup_Cortex-A53x1_AC6:
        $(PROGRESS)
        $(QUIET) $(CC) -c $(TARGET_CPU) $(CPPFLAGS) $(CFLAGS) -o $@ $<
    Hope this helps
    Stephen
