ARM DS 5 IDE does not open
Hello, I downloaded ARM Development Studio 2023 and installed it.
However, the IDE gives an error at startup and a log file is created. I briefly share the details of the log file here. .
!SESSION 2023-09-12 01:47:07.247 -----------------------------------------------
eclipse.buildId=unknown
java.version=11.0.9.1
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=tr_TR
Command-line arguments: -os win32 -ws win32 -arch x86_64
!ENTRY org.eclipse.osgi 4 0 2023-09-12 01:47:18.614
!MESSAGE Application error
!STACK 1
java.lang.IllegalArgumentException: No enum constant com.arm.licensing.toolkits.Toolkit.Type.COMMERCİAL
at java.base/java.lang.Enum.valueOf(Enum.java:240)
at com.arm.licensing.toolkits.Toolkit$Type.valueOf(Toolkit.java:1)
at com.arm.licensing.toolkits.Toolkit.lambda$1(Toolkit.java:101)
at java.base/java.util.Optional.map(Optional.java:265)
at com.arm.licensing.toolkits.Toolkit.<init>(Toolkit.java:101)
at com.arm.licensing.toolkits.LicenseMappingFilesToolkitDatabase.getToolkits(LicenseMappingFilesToolkitDatabase.java:33)
at com.arm.licensing.toolkits.ToolkitSelector.getAllToolkits(ToolkitSelector.java:131)
at com.arm.licensing.ui.wizard.LicensingWizardViewModel.anyToolkitsSupportEvaluation(LicensingWizardViewModel.java:71)
at com.arm.licensing.ui.wizard.LicensingWizardViewModel.<init>(LicensingWizardViewModel.java:38)
at com.arm.licensing.ui.wizard.ui.LicensingWizard.<init>(LicensingWizard.java:54)
at com.arm.licensing.ui.wizard.ui.LicensingWizard.openWizard(LicensingWizard.java:216)
at com.arm.licensing.ui.wizard.ui.LicensingWizard.openWizard(LicensingWizard.java:183)
at com.arm.ds.ui.startup.PreLaunchDialog.displayDialog(PreLaunchDialog.java:29)
at com.arm.ds.ui.startup.StartupApplication.lambda$0(StartupApplication.java:101)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at com.arm.ds.ui.startup.StartupApplication.start(StartupApplication.java:99)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:136)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:596)
at org.eclipse.equinox.launcher.Main.run(Main.java:1467)
!SESSION 2023-09-12 01:48:10.688 -----------------------------------------------
