Placing and Accessing data at/from specific addresses
IDE:                               ARM DS-5 (v5.19.0)
Platform:                        Cortex-R4 (Dual Processor)
Debug agent                   DSTREAM (Connection Type:TCP:DSTREAM)
Execution Environment    Bare-metal
Hello everyone,
I am using attribute for placing the variables in a specific section e.g. "__attribute__((section("datapatharea")))"
//Processor A
__attribute__((section("datapatharea"))) uint8_t rxBuffer[1024];      //Address 1
__attribute__((section("datapatharea"))) uint8_t txBuffer[1024];      //Address 2
__attribute__((section("datapatharea"))) uint8_t localBuffer[1024];   //Address 3
but the problem is that, I want to access them by there address in other processor. Currently i am doing this manually by using there address from map file.
//Processor B
uint8_t * const txBuffer = (uint8_t*)(0x43400000);    // Address 2 = 0x43400000 (From Map file)
uint8_t *traveseTxBuffer = txBuffer;
So, my questions are:
1) what's the best way of doing this?
2) I am looking for a general solution?
I really appreciate your suggestions.
Thanks.
  • I'm not sure I understand but I would probably put those items into a struct and that way I'd only need one address. If you really want to use the map file you could always use a script to generate a header file - but I think that is messier.
  • Thanks daith,
    Yes that's suitable but these are my communication buffer at different level of abstraction layer.
    No i don't want to use map file, I am looking for a way which calculate the before compilation, e.g.
    I knew the base address of section("datapatharea") and sizes of above buffer.
    I really appreciate your answer.
  • Well they'll all be accessible since they are all in the same section so what you want is to restrict visibility of names a bit.
    I think something like this should work, put a statement like this into the header defining rxbuffer for instance
    static uint8 * const rxbuffer = struct__name.rxbuffer;
    These could go into the different headers where you defined rxbuffer etc before.
