I tried to set PC with register.set like this in my .cmm file.
register.set PC 0x80000000
But I got error code after sourcing my .cmm script.
ERROR(CMM26-TAD17): ! Failed to set the register PC(PC) to 0x80000000! Register PC is an unsupported size (32)
Why is it an unsupported size?I can't understand which setting goes wrong?
Thanks.
I guess you are connecting to an Armv8-A (Cortex-Axx) processor.On AArch64 processors, the PC is 64-bits wide, but the value 0x80000000 here in your register.set command is being treated as a 32-bit quantity. You can resolve this by adding an explicit cast, e.g:register.set PC (long)0x80000000The same applies to the general purpose registers X0-X29, LR & SP.By contrast, W0-W30 are 32-bits wide, so you can use, e.g.:register.set W0 0x80000000Hope this helpsStephen
It works correctly with (long).It's also work with 0x80000000L.
