armds_idec "Java was started" error
Attempting to utilize Jenkins with Arm Development Studio 2022.2 to do some builds but the pipeline fails.
This is the command being run (based on the documentation):
C:\"Program Files"\Arm\"Development Studio 2022.2"\bin\armds_idec.exe -nosplash --launcher.suppressErrors -application com.arm.cmsis.pack.project.headlessbuild -data C:\git\workspace -import test_module\code -cleanBuild "Test_Project/Debug"
Here's the relevant log output:
11:46:07 Build Finished. 0 errors, 80 warnings. (took 21s.966ms)
Armds_idec:
Java was started but returned exit code=1
-Xms1024m
-Xmx2048m
--add-opens=java.base/java.io=ALL-UNNAMED
--add-opens=java.base/sun.nio.ch=ALL-UNNAMED
--add-opens=java.base/java.lang=ALL-UNNAMED
--add-opens=java.base/java.util=ALL-UNNAMED
--add-opens=java.base/java.nio.charset=ALL-UNNAMED
--add-opens=java.base/java.nio=ALL-UNNAMED
--add-opens=java.base/java.lang.reflect=ALL-UNNAMED
-Dnashorn.args=--no-deprecation-warning
-Djava.class.path=C:\Program Files\Arm\Development Studio 2022.2\bin\..\sw\ide\\plugins/org.eclipse.equinox.launcher_1.6.400.v20210924-0641.jar
-os win32
-ws win32
-arch x86_64
-launcher C:\Program Files\Arm\Development Studio 2022.2\bin\..\sw\ide\armds_idec.exe
-name Armds_idec
--launcher.library C:\Program Files\Arm\Development Studio 2022.2\bin\..\sw\ide\\plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.2.400.v20211117-0650\eclipse_11602.dll
-startup C:\Program Files\Arm\Development Studio 2022.2\bin\..\sw\ide\\plugins/org.eclipse.equinox.launcher_1.6.400.v20210924-0641.jar
--launcher.overrideVmargs
-cleanBuild Test_Project/Debug
-vm C:\Program Files\Arm\Development Studio 2022.2\bin\..\sw\ide\\../java/bin/server/jvm.dll
-vmargs
-Xms1024m
-Xmx2048m
and the armds_ide.ini:
-startup
--launcher.library
-vm
-vmargs
-Xms1024m
-Xmx2048m
The only thing that was added to the .ini from stock was the -Xms and -Xmx options.
When running from the IDE, there are no errors when I close out. I tried the recommended eclipse option of using "-XX:-UseCompressedOops" but that produces a new error:
Opening 'Test_Project'.
Invalid Arguments: [-XX:-UseCompressedOops, -cleanBuild, Test_Project/Debug, -no-indexer]
Error: Unknown argument: -XX:-UseCompressedOops
-cmsisRoot {path} CMSIS-Packs root directory
-help prints the list of arguments
Armds_idec:
Java was started but returned exit code=2
Also tried removing/modifying the Xms and Xmx options, setting JAVA_HOME, switching between the .dll and .exe for the -vm argument and even re-installing but no luck. The system where the project is to be run is clean: only has the java that was installed with the Arm Development Studio nor has any environment variables like JAVA_HOME set.  The fails occurs whether I try to run through the pipeline or directly from a command prompt. The error also occurs when I try to run armds_idec on my local machine.
