I am running arm53 debug model on my Ubuntu 20.04. I have a Software Success Kit license. Previously I was able to run the model on my ubuntu, with a similar license( the old one just expired and I generated a new one)
I get this error:
In target console:
Iris server started listening to port 7100terminal_0: Listening for serial connection on port 5000terminal_1: Listening for serial connection on port 5001terminal_2: Listening for serial connection on port 5002terminal_3: Listening for serial connection on port 5003Error: license error: License checkout for feature ds_suite_eval with version 0.0202206 has been denied by FlexDynamic back-end. Error code: -5No such feature exists.Feature: ds_suite_evalLicense path: /home/mariag/.arm/ds/licenses/*.lic:8224@california:/opt/arm/licenses/license.dat:FlexNet Licensing error:-5,147In file: /tmp/plgbuild/abs_build/1153836_60931/trunk/work/fastsim/Framework/scx/SCXSimulationEngine.cpp:3271Error: license error: Simulation Engine module unavailable!In file: /tmp/plgbuild/abs_build/1153836_60931/trunk/work/fastsim/Framework/scx/SCXSimulationEngine.cpp:2870Error: license error: License module unavailable!In file: /tmp/plgbuild/abs_build/1153836_60931/trunk/work/fastsim/Framework/scx/SCXSimulationEngine.cpp:2914Error: license error: Simulation Engine module unavailable!In file: /tmp/plgbuild/abs_build/1153836_60931/trunk/work/fastsim/Framework/scx/SCXSimulationEngine.cpp:2870ERROR: uncaught exception occurred. Exception message follows:Error: Wrong version of armctmodel. Version 11.18.16 (API Version 1.2) of the Portfolio was used to build the model. Please use identical major.minor versions of the Portfolio and the Tools.Iris server is reported on port 7100
How do I fix this?
Thank you
Duplicate of community.arm.com/.../cannot-run-debug-model
