FUSA Missing component compiler after import
Arriving from keil uVision.
Compiler:  FUSA safe compiler. 6.16.2
Keil:
ARM DS 2022.2 :
Errors:
Keil.ARM Compiler::Compiler.C Library.Library - Component is not available for current configuration. No component matching current device and toolchain configuration is found
Why doesn't ARM DS take the necessary packs?
What is the problem with the PATH, I changed it to the 6.612 compiler in Keil folder and it still showing error?
EDIT:
In ARM DS
I do see it in Packs but no in Components
