Facing the below error when adding license server in digital studio, do let me know what needs to be checked
The active product is not available with the current license configuration.
Open the IDE > Help > Arm License Manager. Click the button to select active product and select the appropriate edition.
Regards, Ronan
HI Ronan , Thanks for the suggestion , but let me explain the problem in more details , i dont see the option to select the active product post adding the license server credentials, I did try to use the same server details in another Window Workstation ( fresh IDE with no trial license applied )which worked fine but the same isnt working in the linux workstation where I was using Free trial license. Though the license has nothing to do with OS , i did try to use same license server credentials on a windows workstation which had Free Trial license earlier , but it didnt work, so it looks like something with the Free Trial license is blocking the usage , Kindly do suggest any work arounds if you have heard any such cases
Could you share a screenshot of the license manager?Your license server (and eval license) can be added/removed via this GUI. Alternatively, if the license is specified by the environment vatiable ARMLMD_LICENSE_FILE, then that must be cleared manually (via Control Panel in Windows).The 'Active Product' will be shown too. If this is reporting as the evaluation edition, click 'Change' to select the appropriate commercial edition.
My install looks like this:
am unable to add this license server , whereas the same is working on another machine
I've not seen this behavior before.
Could you delete the /home/thanuj.s/.flexlmrc file, and then re-add the license server via the 'Add' button in this view?
If you still have issues, can you share the license file on your server? It is best to do this via a support case (see the support menu above), rather than in this public forum. Please include a link to this thread, and use my name as a reference.
