Invalid executable path: (missing zip-entry name) on ARM streamline 8.1.0 when analyzing traces captured using gatord arm64 android binary
java.lang.IllegalArgumentException: Invalid executable path: (missing zip-entry name)
at com.arm.streamline.analysis.model.threads.IExecutablePath$ExecutablePath. (IExecutablePath.java:44)
at com.arm.streamline.protocol.capture.apc.pass_two.GatorPassTwoSortedEventStreamConsumer.mapExecutablePath(GatorPassTwoSortedEventStreamConsumer.java:79)
at com.arm.streamline.protocol.capture.apc.pass_two.GatorPassTwoSortedEventStreamConsumer.threadProperties(GatorPassTwoSortedEventStreamConsumer.java:426)
at com.arm.streamline.protocol.capture.apc.pass_two.event_queue.GatorPassTwoQueueingEventStream$ThreadPropertiesEventQueueItem.flushToOutputStream(GatorPassTwoQueueingEventStream.java:954)
at com.arm.streamline.protocol.capture.apc.pass_two.event_queue.APCEventQueue.consume(APCEventQueue.java:43)
at com.arm.streamline.protocol.capture.apc.pass_two.event_queue.APCEventQueue.consume(APCEventQueue.java:1)
at com.arm.streamline.protocol.misc.event_queue.AbstractEventQueue.flush(AbstractEventQueue.java:169)
at com.arm.streamline.protocol.misc.event_queue.AbstractEventQueue.flushUpTo(AbstractEventQueue.java:105)
at com.arm.streamline.protocol.capture.apc.pass_two.event_queue.APCEventQueues.flushUpTo(APCEventQueues.java:76)
at com.arm.streamline.protocol.capture.apc.pass_two.APCFrameRecordReloader.lambda$0(APCFrameRecordReloader.java:273)
at com.arm.utils.function.Throwing.closeAlways(Throwing.java:241)
at com.arm.streamline.protocol.capture.apc.pass_two.APCFrameRecordReloader.run(APCFrameRecordReloader.java:219)
at com.arm.streamline.protocol.capture.apc.pass_two.APCPassTwo.run(APCPassTwo.java:772)
at com.arm.streamline.capture.apc.APCDatabaseGenerator$AbstractAPCDatabaseGeneratorProcessor.run(APCDatabaseGenerator.java:188)
at com.arm.streamline.capture.apc.APCDatabaseGenerator.processRecords(APCDatabaseGenerator.java:438)
at com.arm.streamline.databrowser.AbstractDatabaseGenerator.generateDatabase(AbstractDatabaseGenerator.java:52)
at com.arm.streamline.analysis.session.SessionProcessor.produceReport(SessionProcessor.java:614)
at com.arm.streamline.capture.apc.APCCapture.lambda$17(APCCapture.java:534)
at com.arm.streamline.capture.apc.APCCapture.doIfValidLicence(APCCapture.java:587)
at com.arm.streamline.capture.apc.APCCapture.analyze(APCCapture.java:505)
at com.arm.streamline.databrowser.DocumentsView.lambda$0(DocumentsView.java:273)
at com.arm.streamline.common.utility.Task.run(Task.java:259)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:834)
Above popup seen with gatord 8.1.0 but no such pop up seen with older gatord 7.7
