ARM 30 day evaluation - 2020.1 Version
Is it possible to get 30 day free evaluation for ARM 2020.1 version?
  • Hi Hariram,
    My name is Christian, and I work here at Arm.
    I'm afraid we only offer evaluation licenses for the latest verison of Arm DS which is 2022.1
    Many thanks,
    Christian.
  • Hi Christian,
    I have installed ARM DS version 2022.1. I wanted to use its 30 days evaluation version but I am facing login issues when I go for obtaining the 30 days evaluation gold license for it.
    I am able to login using the login credentials in the ARM website but when I enter the same login credentials using ARM DS application in
    Help -> ARM License Manager -> Configure for license I get an error message stating "Login failed. Check your email address and password are correct."  I referred some similar cases that are there in ARM community but could not solve this problem. Can you guide me on this ASAP.
    Thank you.
  • Hi Anupama,
    Unfortunately there is a known issue with issuing evaluation licenses at the moment. Sorry this has happened to you.
    Please raise a support case here, so the issue can be tracked and resolved.
    Christian.
