Hi,all
the Test Env is DS-5 and DSTREAM-ST and arm development board, When I execute csat.exe drr cmd , the error "Autotune failure. Please try to reboot target and select a lower frequency using the AutotuneMaxFreq config item." occured.
I can't solve this error with cmd "cfb JTAGAutoMaxFreq 2000" and "cfb JtagClockFreq 2000",
so how can I solve this problem,Thanks!
%> cfb JTAGAutoMaxFreq 20000Config item JTAGAutoMaxFreq was set to 20000%> drr 0xff0Reading from device no. 12: CSMEMAP_2Failed to read register 0x00000ff0 for device no 12. Autotune failure. Please try to reboot target and select a lower frequency using the AutotuneMaxFreq config item.Error: Failed to read register 4,080 on device CSMEMAP_2%> cfb JtagClockFreq 2000Config item JtagClockFreq was set to 2000
%> cfb JTAGAutoMaxFreq 2000Config item JTAGAutoMaxFreq was set to 2000%> drr 0xff0Reading from device no. 12: CSMEMAP_2Failed to read register 0x00000ff0 for device no 12. No connection to target.Error: Failed to read register 4,080 on device CSMEMAP_2
HiMy name is Stephen and I work at Arm.From the console output you showed, it looks like reducing the clock frequency has avoided the autotune failure, so I suggest you keep that.Sorry, I can't explain why the "drr" command is still failing. What platform are you connecting to? Have you done an auto-detect?Which version of Development Studio, exactly, are you using? Recent versions of Arm DS now include "CSAT600", which can be launched withcsat -cs600I recommend you switch to that.See developer.arm.com/.../How-to-use-CSAT600Hope this helpsStephen
csat -cs600
Hi, Stephen
thank you for your help! The issue has been resolved.
the fail proceed as follows:
con TCP:.....
chain dev=auto clk=20000 is ok
autodetect read-rom is ok
now drr dev**.0 return fail
the successful proceed as follows:
setprobe DSTREAM-ST // the default is DSTREAM
cfb ScanChainJtagFreqs 20000 //the default is 2000T
cfb JtagClockFreq 20000
now drr dev**.0 return ok
our traget is a emulation device with low speed.
thanks.
Thanks for letting us know that this problem is resolved :)
