I am trying to run the fireworks example following this video: https://www.youtube.com/watch?v=HiXUh4Wx2og
First of all, the names in the video do not match with the contents of the actual examples directory. I think I found similar setup to what the video points to. (if you could help me with initial setup for the project that would be great!)
I am able to build the project successfully:
12:32:28 **** Incremental Build of configuration Debug for project fireworks_Armv8-Ax1-FVP_AC6 ****make all make: Nothing to be done for 'all'.12:32:28 Build Finished. 0 errors, 0 warnings. (took 118ms)
When I add the debug configuration for the project, i try to run the project and get a following result:
Iris server started listening to port 7100terminal_0: Listening for serial connection on port 5000terminal_1: Listening for serial connection on port 5001terminal_3: Listening for serial connection on port 5002terminal_2: Listening for serial connection on port 5003libGL error: MESA-LOADER: failed to open iris: /opt/arm/developmentstudio-2022.1/sw/models/bin/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/dri/iris_dri.so) (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)libGL error: failed to load driver: irislibGL error: MESA-LOADER: failed to open swrast: /opt/arm/developmentstudio-2022.1/sw/models/bin/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/dri/swrast_dri.so) (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)libGL error: failed to load driver: swrastX Error of failed request: BadValue (integer parameter out of range for operation) Major opcode of failed request: 149 (GLX) Minor opcode of failed request: 3 (X_GLXCreateContext) Value in failed request: 0x0 Serial number of failed request: 100 Current serial number in output stream: 101My suspicion is that it cannot find the GLIBCXX_3.4.29.
I do have it on my machine. I run /usr/lib/x86_64-linux-gnu$ strings /usr/lib/x86_64-linux-gnu/libstdc++.so.6 | grep GLIBCXX_3.4.29 and it shows that it is there. I suppose it is located somewhre where armds is not looking. I might have to change some path somewhere but I have no idea where and how to do that.
Thank you!
Of course after I spent 2 days trying to figure it out AND after asking a question here I was able to fix it before I got the answer =)
Hi Maria thank you for posting your question. If you could, please may you reply with what your solution was? Many thanks.
Hi Annie, I just copied the library it was requesting to the bin directory of the arm DS:
cp /usr/lib/x86_64-linux-gnu/libstdc++.so.6 /opt/arm/developmentstudio-2022.1/sw/models/bin/I feel like its just a quick fix for the issue and there's might be more things I will have to move around.
I believe the solution is described here:https://developer.arm.com/documentation/101469/2021-2/Installing-and-configuring-Arm-Development-Studio/Additional-Linux-libraries
The YouTube video is quite old, refering to the now obsolete DS-5 toolchain, though the general information does still apply to Arm Development Studio.The readme supplied with the Fireworks (and all) examples provided with Development Studio provides detailed information on how to run them, and what features they are highlighting. Further references:
https://developer.arm.com/documentation/101469/2021-2/Projects-and-examples-in-Arm-Development-Studio/Examples-provided-with-Arm-Development-Studiohttps://developer.arm.com/documentation/101469/2021-2/Projects-and-examples-in-Arm-Development-Studio/Import-the-example-projects
Yes I installed all the additional libraries. They were installed in one place and ARM DS was looking for it somewhere else. Probably because different linux kernels have different paths, they also change depending on the version.And yes, that video is old =) some debug configurations are not present in the current armds package(probably they are named differently now).
