Mali G52 - Failed to create reader for mali GPU # 0
Streamline version: Version 8.0.0, Build 20220217_150925 windows 64-bit.
Device: Mali G52(Bifrost - r21p0)  on Android.
If any GPU perf counters are selected from "Add counters from a template", the capture will not start with:
If I capture without any mali counters selected, I can successfully get a capture(with only CPU info).
  • Hi ; can you please provide a debug log from gatord. You can do so as follows:
    adb push <streamline-install>/bin/arm64/gatord /data/local/tmp/
    adb shell /data/local/tmp/gatord -d -S no -A find / 1> /data/local/tmp/gatord.log 2>&1
    < try counter configuration, you may need to use the TCP/Advanced view in Streamline rather than the Android view >
    < stop gatord with ctrl-c, once the above error message is seen >
    adb pull /data/local/tmp/gatord.log
    This file should help identify the reason for the failure.
    Ben
  • Hi Ben,
    Thank you for your reply.
    I cannot find out how to upload the full log here. :(
    I am posting what I think is relevant here:
    [56634.1078929] DEBUG: #23473 (mali_userspace/MaliDeviceApi.cpp:234): MaliDeviceApi: Failed setting ABI version ioctl - may be r21p0 or later...
    [56634.1079485] DEBUG: #23473 (mali_userspace/MaliDeviceApi.cpp:550): MaliDeviceApi: ABI version: 11.17
    [56634.1116110] SETUP: #23473 (mali_userspace/MaliDeviceApi.cpp:88): Mali GPU counters
    Successfully probed Mali device /dev/mali0 as Mali-G52 (0x7402 r1p0), 2 L2 Slices, 128-bit Bus, 6 Shader Cores (sparse layout, mask is 0x77).
    [56634.5433418] DEBUG: #23473 (mali_userspace/MaliHwCntrDriver.cpp:54): Added counter 'ARM_Mali-TGOx_MESSAGES_SENT' @ 0 4
    [56634.5434768] DEBUG: #23473 (mali_userspace/MaliHwCntrDriver.cpp:54): Added counter 'ARM_Mali-TGOx_MESSAGES_RECEIVED' @ 0 5
    [56634.5435168] DEBUG: #23473 (mali_userspace/MaliHwCntrDriver.cpp:54): Added counter 'ARM_Mali-TGOx_GPU_ACTIVE' @ 0 6
    ......(Other counter probe infomation)
    [56656.2503618] DEBUG: #23896 (Child.cpp:346): Started ext_source agent
    [56656.2503846] DEBUG: #23895 (Child.cpp:358): Waiting for agent complete
    [56656.2505191] DEBUG: #23895 (mali_userspace/MaliDeviceApi.cpp:479): MaliDeviceApi: Failed sending hwcnt reader ioctl
    [56656.2505678] DEBUG: #23895 (mali_userspace/MaliDeviceApi.cpp:479): MaliDeviceApi: Failed sending hwcnt reader ioctl
    ......(repeat "Failed sending hwcnt reader ioctl" about 1000 times)
    [56656.2908737] DEBUG: #23895 (mali_userspace/MaliDeviceApi.cpp:479): MaliDeviceApi: Failed sending hwcnt reader ioctl
    [56656.2909118] DEBUG: #23895 (mali_userspace/MaliDeviceApi.cpp:479): MaliDeviceApi: Failed sending hwcnt reader ioctl
    [56656.2909513] ERROR: #23895 (mali_userspace/MaliHwCntrSource.cpp:52): Failed to create reader for mali GPU # 0. Please try again, and if this happens repeatedly please try rebooting your device.
    [56656.2910466] DEBUG: #23895 (Sender.cpp:115): Sending data with length 124
    I hope this is enough for you to identify the reason. If not, I'll try somehow upload the full log.
  • Just to confirm - have you tried power cycling the device?
    Cheers,
    Pete
  • Tried reboot the device. Same problem.
    Thank you.
