How to run ARM compiler from Windows command line?
Hi
I have installed Arm Development Studio Gold Edition Free Trial on Windows and have successfully built an executable using the IDE. I now want to build from the command line.
This web page:
Building your first embedded image (arm.com)
has link:
configure your environment in order to run Arm Compiler 6 from the command-line
But that link is broken.
Where can I find information on how to set environment variables for working from the command line?
Best regards
David
