armlink stuck in armcc
Hi
I want to use armcc to pre-process my scatter file:
#! armcc -E
but armlink gets stuck.
If I kill armcc.exe armlink returns an error that armcc terminated (because of killing).
Any idea?
  • Hi,
           I tried to run the following command with ARM Compiler 5.05u1:
    armcc -E scatter.scat
    Where scatter.scat is a scatter file in an example project but I don't see armcc calling armlink.
    Can you expand a bit on what are you trying to do or what command line you are using ? What version of ARM Compiler are you using for your project ?
    Best Regards,
    Stefano
  • Stefano
    I have a scatter file which instructs armlink (also 5.05u1) to pre-process it with armcc
    For example like this:
    #! armcc -E
    #define TEST 1
    #if TEST == 1
    #error Works
    #endif
    If I try this, armcc does not stop (as it is waiting for more input) and therefore armlink hangs.
    Using instead:
    #! arm-none-eabi-gcc -E -P -x c
    works fine.
  • Hi,
         Unfortunately, due to a defect that affects ARM Compiler 5.05, 5.05 update 1, and 5.05 update 2, you will need to temporarily separate the scatter-file preprocessing from the link step as a workaround:
    1. Use armcc to preprocess the scatter-file;
    2. Pass the result of 1 as your scatter-file input to armlink.
    We expect this issue will be fixed in the next ARM Compiler 5 release. Sorry for the inconvenience this issue is causing to you.
    Best Regards,
    Stefano
  • Ok, thanks for the info.
    Cheers,
    42Bastian
