Hi
There are some instances when you need to call ARM Instructions in C Code.
Best way is to use __asm {
This is good when no issue is there. But some times, you get some error
errot #1113 arm: inline assembler not permitted when generating thumb code
The cause is due to compiler issues , But if you dont want to modify the compiler settings any solution for above problem ?
Which compiler are you using?
Is you are using ARM's compiler (armcc) there are restrictions on which instruction sets it can handle. See:
ARM Compiler armcc User Guide : 7.3 Restrictions on inline assembler support in the compiler
