I encountered with the error "Unable to execute API call /api/v1/connect" when getting evaluation key from ARM DS IDE
I have installed ARM DS IDE and tried to get evaluation license at the start.
But I failed to login and encountered with the following error:
I have found similar issues registered previously in this bulletin.
Can you check again if the license server is working or not?
Thank you,
Sungkun Moon
