Dear team:
I am using the Eclipse for DS-5 v5.27.1 software to develop my project, i got some issue when i do the debug configuration. Here are the the issue pictures.
By the way, i click on th restore deault button before, is that the root cause of the issue?
How can i solve the problem, i can not build my project now.
Best wishes~!
Hi,It's good to notice that ;) Thx
Hi there, I have moved your question to the Development Studio forum. Thanks :)
Hi XingyuI suspect that you may have accidentally unticked "Generate Makefiles automatically". This effective converts your project from a Managed Builder project to a makefile-based project.If you re-tick this box, you should find that the toolchain Settings panel is restored.As a last resort, you can always create a new C project afresh.Hope this helps
Hi,Stephen . The Problem has been solved by your suggestion. Appreciate! Thanks for your help~
Thanks for the confirmation!
