Site
Search
User
Site
Search
User
Support forums
Arm Development Studio forum
DS-5 licensing issue
Jump...
Cancel
Locked
Locked
Replies
Subscribers
118 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Fabrice DECROP
over 12 years ago
Note: This was originally posted on 2nd July 2013 at
http://forums.arm.com
I encoutered problems with my 30-days licensing of DS-5.
I'm working on Altera SoC FPGA devkit, my computer is running with Ubuntu 12.04, and I launch elcipse (after having launched Quartus, because I don't know if it's needed or not).
I get a licence.dat file from silver.arm.com, with my HostID, refered to my eth0 card.
I put this file in Help -> ARM Licence Manager. I also see the local server from LM_LICENCE_FILE. One must notive that there is "no toolkit available" in the "Select the toolkit that you intend to use".
Then in "Debug configurations" of Eclipse, I can see my USB Blaster II, wich is the correct connection for debug. But when I try to debug, I get this error message :
e arguments: -pluginCustomization /home/p1215579/.ds-5/workbench/pluginCustomization.ini -os linux -ws gtk -arch x86 -product org.eclipse.platform.ide
Error
Tue Jul 02 14:58:24 CEST 2013
Unable to connect to Altera-SoCFPGA-HardwareLib-GNU-Debug. Failed to connect to the device
The desired vendor daemon is down.
Check the lmgrd log file, or try lmreread.
Feature: ds_debugger_cmsisdap
Vendor:Host: trc-cgy-wap1
License path: /home/p1215579/Téléchargements/license.dat:1800@trc-cgy-wap1:
FLEXnet Licensing error:-97,121
For further information, refer to the FLEXnet Licensing documentation,
available at "www.flexerasoftware.com".
Thanks in advance for your help,
Regards,
Fabrice DECROP
Scott Douglass
over 12 years ago
You should try generating a new license using the activation code from
http://ds.arm.com/al...a-eval-edition/
in the ARM Licence Manager dialog. I expect you will need to choose the Altera toolkit in that dialog.
I think the evaluation license you get from silver.arm.com does not include connecting to the Altera USB Blaster.
Also I don't expect to see LM_LICENSE_FILE used nor a local license server for a DS-5 eval license; I suspect those were setup for something else on your machine. But I don't expect them to do any harm.
Cancel
Vote up
0
Vote down
Cancel
Fabrice DECROP
over 12 years ago
It works !!! I can break in HWlib code from Altera.
i also keep the LM_LICENSE_FILE in the ARM licence manager dialog. It seems to have no effect on the licence.
Thank you for all,
Regards,
Fabrice DECROP
Cancel
Vote up
0
Vote down
Cancel
