Breakpoints not working in C code, only in assembly?
I am running some example program in ARM Development Studio using FVP (fixed virtual platforms) simulator for A53.
All is OK, I can run the app.
However, the problem is the breakpoints: they don't work in C code, the work only in .S files assembly.
What could be the problem?
Model parameters are -C bp.secure_memory=false -C cache_state_modelled=0.
  • Hi Danijel
    As you've probably spotted, the "startup_Cortex-A53x1_AC6" example is a makefile-builder project that is based on the "startup_Armv8-Ax1_AC6" example.
    If you want to extend the "startup_Cortex-A53x1_AC6" example by adding a new source file e.g. hello.c then, as a starting point, you must add it to the /src folder of the "startup_Armv8-Ax1_AC6" example, otherwise hello.c will not get compiled.
    Also, check that symbol files are loaded for all exception levels that your code executes, e.g.:
    add-symbol-file "${workspace_loc:/startup_Cortex-A53x1_AC6/startup_Cortex-A53x1_AC6.axf}" EL1N:0
    I have tested this with the addition of a new C file hello1.c containing function hello1(), and the addition of a new function hello2() in main.c, with both functions being called from main(), and both breakpoints are hit as expected - see attached screenshot.
    If this still doesn't work for you, then revert back to the original "startup_Cortex-A53x1_AC6" example, and try setting a breakpoint on nudge_leds() in timer_interrupts.c.  I've also tested that this works as expected.
    Stephen
  • Hi Stephen,
    What I have done is I made a new project in ADStudio, than I added a folder with /src and /asm files from the example you mention, and as a last step I added another folder with a bunch of my C source files. It all compiles, builds and runs nicely.
    I put a few breakpoints in startup.S, and they all work. Also I placed a few breakpoints into GIC*.c and they all work.
    However, breakpoints in main.c don't work. Main.c is still in the /src dir as GIC files are. So it's not even my own folder.
    Also, none of the breakpoints work in my own source.
    What could I have done to cause this strange behavior? I modified main.c, added some lines, however, nothing suspicious. It builds and runs nicely!
  • Some more info.
    I can step through the code until "erret" line below:
    bl SetSPISecurityAll
    // Set up EL1 entry point and "dummy" exception return information,
    // then perform exception return to enter EL1
    .global drop_to_el1
    drop_to_el1:
    adr x1, el1_entry_aarch64
    msr ELR_EL3, x1
    mov x1, #(AARCH64_SPSR_EL1h | \
    AARCH64_SPSR_F | \
    AARCH64_SPSR_I | \
    AARCH64_SPSR_A)
    msr SPSR_EL3, x1
    eret
    Until eret is executed here it's all EL3 memory, and than EL1N. When I try to dissasembly Show in Source it says "no source available for address: EL1N...".
    Is this drop_to_el1 the problem?
  • Hi Danijel,
    The different exception levels (ELx) are essentially different (but overlapping) memory spaces.
    As Stephen mentioned above, the solution is to load the debug symbols (you do not need to reload the image itself) to the necessary EL level, which is done by the below command (or from the Load menu item in the Debug Control pane).
    Note how EL1N:0 is specified as the 'offset' - this means it will be loaded to EL1N no matter what EL level the core happens to be in when the command is executed:
    You can see this being set in the default debug configuration for the Cortex-A53 example you are using:
    The only other possible cause I can think of may be that your main.c is not compiled for debug (-g),
  • Understood, and resolved, thank you so much Ronan.
    Thank you Stephen too.
