Hello, all
I installed Fast models evaluation(FE000-KT-00002-r9p1-26rel0.tgz). but it is not working for license problem.
i attached the file (error screen and license file).
Thanks in advance,
BR,
MK
Based on the error message, the license has expired. Evaluation licenses are for a limited time, 30 days from memory.
I installed it yesterday ( 1/19/2015), but the result is license has expired.
how can i solve this problem? do you have idea or recommend item?
The evaluation period is based on when you (or whoever downloaded it) registered the license, not on when you installed the tool.
If you contact ARM's support team (support@arm.com) they can tell you when the license was registered.
