Site
Search
User
Site
Search
User
Support forums
Arm Development Studio forum
Dstream probe questions
Jump...
Cancel
Locked
Locked
Replies
Subscribers
118 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
nicolas vassal
over 12 years ago
Note: This was originally posted on 4th March 2013 at
http://forums.arm.com
I just received a Dstream probe to do trace on an Omap 3530 (CortexA8) processor.
I started to setup the device but I have the following issues:
[1] I installed DS5 & Dstream on a windows XP (SP3) but the USB driver installation of the Dstream fails.
Each time I plug the probe (USB) to the PC, windows ask for the driver to install ... I follow the procedure given by arm and indicate the correct folder for the drivers.
The installation starts with files copy ... but at the end of the setup an error message indicates that the installation failed without giving further indications.
Does someone already had that kind of problem?
[2] As I'm not able to connect the Dstream to the host PC via USB I have connected the probe via Ethernet.
This is working fine but it seems that, when connected via ethernet, it is not possible to do trace capture with the ETM interface.
Looks like it is only possible to use the 4KB trace buffer embedded in the OMAP.
Someone can confirm?
Thanks for your help!
Regards,
Nicolas.
Scott Douglass
over 12 years ago
Note: This was originally posted on 8th March 2013 at
You are right that the JTAG connection will not handle external trace, but the type of trace is not automatically selected by the cable connected
The choice between ETB and TPIU (external trace) is made by choosing the platform and DTSL Options. DS-5 doesn't supply a platform for OMAP3530EVM. And the closest platforms [Mistral > AM3730, TI > OMAP 3530 (Generic) and TI > OMAP 35XX (Generic)] have only "Debug and ETB Trace" options. Which platform have you selected in the debug configuration that you are using?
I suggest you try creating your own platform by using Debug Hardware Config and cdbimporter. See
http://infocenter.ar...h/BGBIICAJ.html
http://infocenter.ar...m/CIHEJGAB.html
and
http://infocenter.ar...m/CIHFJGAF.html
I tried this on my OMAP3530EVM and was able to select the DSTREAM in the DTSL options, but I didn't get any trace clock (or trace). I suspect there is some target pinmuxing required.
Cancel
Vote up
0
Vote down
Cancel
Scott Douglass
over 12 years ago
and
Cancel
Vote up
0
Vote down
Cancel
