Site
Search
User
Site
Search
User
Support forums
Arm Development Studio forum
Problems with ARM DS-5
Jump...
Cancel
Locked
Locked
Replies
Subscribers
118 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Bernd Proe
over 12 years ago
Scott Douglass
over 12 years ago
Note: This was originally posted on 21st March 2013 at
http://forums.arm.com
The Community Edition of DS-5 does not include any compilers, so it seems you've installed something else (some gcc?).
It would be useful to be able to see the exact command that is failing. And, if you're using gcc then adding '-Wl,-v' will put the linker in verbose mode, which might emit a clue.
Also, you can try right-clicking on Test.o and opening it with ELF Content Editor and look in it's symbol table and see if it has the symbol 'main' is defined and exported.
Cancel
Vote up
0
Vote down
Cancel
Bernd Proe
over 12 years ago
Thanks for you answer.
I'm quite new with these and I hope to give you the right answers
-I installed MinGW as compiler.
-I also installed ARM DS-5 (downloaded from Keil)
-I added (Window / C/C++ /Build / Envirenment "Variable : PATH -- Value D:\ARMDS5\bin )
-The exact Console text is
**** Build of configuration Debug for project Test ****
make all
'Building file: ../Test.cpp'
'Invoking: GCC C++ Compiler'
arm-linux-gnueabihf-g++ -I"D:\ARMDS5\include" -I"D:\MinGW\include" -O0 -g3 -Wall -c -fmessage-length=0 -MMD -MP -MF"Test.d" -MT"Test.d" -o "Test.o" "../Test.cpp"
In file included from D:\Bernd\ARMDS5\include/rw/_defs.h:37:0,
from D:\ARMDS5\include/iosfwd:35,
from D:\ARMDS5\include/iostream:35,
from ../Test.cpp:7:
D:\ARMDS5\include/rw/_config.h:40:38: fatal error: rw/config/rwconfig_std.h: No such file or directory
compilation terminated.
make: *** [Test.o] Error 1
**** Build Finished ****
The Erros at the Problem lists are
Description Resource Path Location Type
make: *** [Test.o] Error 1 Test C/C++ Problem
fatal error: rw/config/rwconfig_std.h: No such file or directory Test line 40, external location: D:\ARMDS5\include\rw\_config.h C/C++ Problem
unforunetly I dont get a Test.o anymore.
Its not clear for me where I should add the '-Wl,-v' .
I hope that are the information you want.
Cancel
Vote up
0
Vote down
Cancel
Scott Douglass
over 12 years ago
Cancel
Vote up
0
Vote down
Cancel
