FFT filter code for Sam4s2a
The below code is FFT filter code for SAM4SD32C
uint32_t ifftFlag = 0;
uint32_t doBitReverse = 1;
uint32_t fftSize = 1024;
#define TEST_LENGTH_SAMPLES 2048
for(xt=0;xt<2048;xt++)
                mt[xt] =  adc_get_channel_value(ADC, ADC_CHANNEL_0);
               testInput_f32_10khz[xt] =(0.6-((float)mt[xt]/4100.00))*16.00;
                delay_us(10);
            arm_cfft_f32(&arm_cfft_sR_f32_len1024, testInput_f32_10khz, ifftFlag, doBitReverse);
            arm_cmplx_mag_f32(testInput_f32_10khz, testOutput, fftSize);
            arm_max_f32(testOutput, fftSize, &maxValue, &testIndex);
            maxi = maxValue;
            printf("Maxi %d test Index %d\n",maxi,testIndex);
I trying to work out the same code in SAM4S2A controller
But the output values maxi and testIndex are changing.Due to this output is not as getting and testIndex value is getting 0.
can any one help me out to resolve the issue.
  • You need to give more information!
    For a start, you haven't shown the definitions of maxi and testIndex
    Is that not what you expect?
    If they never changed, why would you bother calculating them? Just use constants!
  • Hello Andy,
    Please find below code in detail
    the output value testindex is giving zero even the voice is generated form external source.
    The same code is working with Sam4SD32C now i m just changing the controller to Sam4S2A and tying to execute.
    uint32_t ifftFlag = 0,testIndex = 0;
    float32_t testOutput[TEST_LENGTH_SAMPLES/2],testInput_f32_10khz[TEST_LENGTH_SAMPLES];
    float32_t maxValue;
    int maxi=0;
    while(1)
            delay_us(10);
            maxi = maxValue;
          if(testIndex>=990)
             printf("Voice\n");
          if(testIndex<990)
             printf("No Voice\n");
    the code.
  • hello can any one please check and give the response asap
  • So what checking have you done?
    You have a "working" example, and a "non-working" one - step through them both, and see where they diverge ...
  • I checked in the way you said for both codes...
    But, the below line out parameter is not giving result as expected it is returning zero.
    there is no changes in both the codes.
  • Are you sure that the data you're passing into that function is valid?
    To compare the STM32 & SAM4 versions, you need to ensure that you are using the same input data !
    Are you sure this is actually giving you good data?
    Maybe the maximum of that data is really zero ?
    After verifying all the above, try steppping into that function to see what's happening
