Marketplace doesn't work
I have just installed ARM Developement Studio to evaluate this IDE before purchase. As I have been working in Eclipse based IDEs, the first thing I wanted to do was to download DevStyle theme from eclipse marketplace, because I can work only with dark themes.
And there is a problem on just beginning, because it doesn't work. I got communicate:
" Cannot complete the install because one or more required items could not be found.
  Software being installed: DevStyle (includes Darkest Dark Theme) 1.11.0.201909171704 (com.genuitec.eclipse.theming.feature.feature.group 1.11.0.201909171704)
  Missing requirement: Startup 1.11.0.201909171704 (com.genuitec.eclipse.startup 1.11.0.201909171704) requires 'bundle org.eclipse.wst.common.frameworks 0.0.0' but it could not be found
  Cannot satisfy dependency:
    From: DevStyle (includes Darkest Dark Theme) 1.11.0.201909171704 (com.genuitec.eclipse.theming.feature.feature.group 1.11.0.201909171704)
    To: com.genuitec.eclipse.startup [1.11.0.201909171704] "
Some plugins works, some not. This is first time when I have problems with marketplace and it saddens me a bit that such IDE has problems from the very beginning.
Any suggestions what is wrong? I have 4 other IDEs based on Eclipse, all of them works ok.
Arek
  • Hi Arek,
    The Market Place needs a reference to the Eclipse platform software repository to automatically resolve the dependencies of the plug-in you are trying to install. This reference is currently missing (I raised a bug with the development team) but it can be trivially added, from the Eclipse Preferences:
    • Go to Preferences -> Install/Update -> Available Software Sites
    • Push the Add... button
    • Enter the following URL, with the name of your choosing: http://download.eclipse.org/releases/neon ("Eclipse Neon Release Software Repository" is a fair name)
    This is what you should see:
    After that step, you will be able to install DevStyle from the Market Place.
    Best regards,
      Romain Castell
  • Yes, that did the job. Thanks for help, now I can start work.
    Arek
