DS-5 error code 132
Dear All,
When I run DS-5 debugger with gui, it show a connection failed
But I have no idea about following error message, please kindly check:
>>>>>>>>>>>>>>>>>>>>>>>>Connection Failed>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
" Unable to connect to HelloWorld_A9.
The script file ( rtsm_launcher.py ) failed during execution:
Failed to launch model FVP_VE_Cortex-A9x4.
Command:
/tools/ARM/DS-5/v5.27.1/bin/FVP_VE_Cortex-A9x4 --cadi-server --print-port-number
exited with error code: 132
See Target Console view for more details"
>>>>>>>>>>>>>>>>>>>>>>>>>>>Exception Stack Trace>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
com.arm.debug.control.LaunchException: The script file ( rtsm_launcher.py ) failed during execution:
Failed to launch model FVP_VE_Cortex-A9x4. Command:
at com.arm.debug.control.target.AbstractTargetController.runSetupScript(AbstractTargetController.java:193)
at com.arm.debug.control.target.AbstractTargetController.setupTarget(AbstractTargetController.java:70)
at com.arm.debug.control.ConnectionController.doPreDebugServiceInitialization(ConnectionController.java:660)
at com.arm.debug.control.ConnectionController.doInitialize(ConnectionController.java:568)
at com.arm.debug.control.ConnectionController.manageThreadModelAndInitialize(ConnectionController.java:550)
at com.arm.debug.control.ConnectionController.manageProgressResourceAndInitialize(ConnectionController.java:488)
at com.arm.debug.control.ConnectionController.initialize(ConnectionController.java:414)
at com.arm.debug.control.ConnectionManager.createConnection(ConnectionManager.java:284)
at com.arm.debug.launcher.TargetLauncher.launch(TargetLauncher.java:20)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:885)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:739)
at com.arm.debug.control.VariableResolvingLaunchConfiguration.launch(VariableResolvingLaunchConfiguration.java:273)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1039)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1256)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Caused by: com.arm.debug.launch.script.ScriptException: The script file ( rtsm_launcher.py ) failed during execution:
at com.arm.debug.launch.script.PythonScriptRunner.run(PythonScriptRunner.java:102)
at com.arm.debug.launch.script.TargetControlScriptRunner.run(TargetControlScriptRunner.java:32)
at com.arm.debug.control.target.AbstractTargetController.runSetupScript(AbstractTargetController.java:190)
... 14 more
Caused by: Traceback (most recent call last):
File "/tools/ARM/DS-5/v5.27.1/sw/debugger/configdb/Scripts/rtsm_launcher.py", line 383, in <module>
modelLauncher.launch()
File "/tools/ARM/DS-5/v5.27.1/sw/debugger/configdb/Scripts/rtsm_launcher.py", line 161, in launch
raise RuntimeError, \
RuntimeError: Failed to launch model FVP_VE_Cortex-A9x4. Command:
at org.python.core.PyException.doRaise(PyException.java:198)
at org.python.core.Py.makeException(Py.java:1337)
at org.python.core.Py.makeException(Py.java:1341)
at org.python.pycode._pyx1.launch$11(/tools/ARM/DS-5/v5.27.1/sw/debugger/configdb/Scripts/rtsm_launcher.py:206)
at org.python.pycode._pyx1.call_function(/tools/ARM/DS-5/v5.27.1/sw/debugger/configdb/Scripts/rtsm_launcher.py)
at org.python.core.PyTableCode.call(PyTableCode.java:167)
at org.python.core.PyBaseCode.call(PyBaseCode.java:138)
at org.python.core.PyFunction.__call__(PyFunction.java:413)
at org.python.core.PyMethod.__call__(PyMethod.java:126)
at org.python.pycode._pyx1.f$0(/tools/ARM/DS-5/v5.27.1/sw/debugger/configdb/Scripts/rtsm_launcher.py:386)
at org.python.core.PyCode.call(PyCode.java:18)
at org.python.core.Py.runCode(Py.java:1386)
at org.python.core.__builtin__.execfile_flags(__builtin__.java:535)
at org.python.util.PythonInterpreter.execfile(PythonInterpreter.java:286)
at com.arm.jython.Jython.runScript(Jython.java:81)
at com.arm.jython.Jython.runScript(Jython.java:94)
at com.arm.debug.launch.script.PythonScriptRunner.run(PythonScriptRunner.java:91)
... 16 more
>>>>>>>>>>>>>>>>>>>>>>>>>>>Session Data>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
eclipse.buildId=4.5.2.M20160212-1500
java.version=1.8.0_45
java.vendor=Oracle Corporation
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -product com.arm.ds.ult
Command-line arguments: -os linux -ws gtk -arch x86_64 -product com.arm.ds.ult
Thanks & Best Regards,
YL Shen
