!SESSION 2012-07-26 15:11:15.674 -----------------------------------------------eclipse.buildId=I20110613-1736java.version=1.6.0_04java.vendor=Sun Microsystems Inc.BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_USFramework arguments: -pluginCustomization C:\DOCUME~1\WK49264\LOCALS~1\Temp\pluginCustomization17020.ini -product org.eclipse.platform.ideCommand-line arguments: -pluginCustomization C:\DOCUME~1\WK49264\LOCALS~1\Temp\pluginCustomization17020.ini -os win32 -ws win32 -arch x86 -product org.eclipse.platform.ide!ENTRY org.eclipse.osgi 4 0 2012-07-26 15:11:21.752!MESSAGE Application error!STACK 1java.lang.UnsatisfiedLinkError: com.slickedit.eclipse.SlickEditSystem.getAlertGroupVisible(I)I at com.slickedit.eclipse.SlickEditSystem.getAlertGroupVisible(Native Method) at com.slickedit.swt.StatusIcon.createControl(StatusIcon.java:55) at org.eclipse.ui.menus.WorkbenchWindowControlContribution.delegateCreateControl(WorkbenchWindowControlContribution.java:102) at org.eclipse.ui.internal.menus.DynamicToolBarContributionItem.createControl(DynamicToolBarContributionItem.java:280) at org.eclipse.jface.action.ControlContribution.fill(ControlContribution.java:97) at org.eclipse.jface.action.ToolBarManager.update(ToolBarManager.java:353) at org.eclipse.jface.action.ToolBarManager.createControl(ToolBarManager.java:111) at org.eclipse.ui.internal.menus.TrimContributionManager$ToolBarTrimProxy.dock(TrimContributionManager.java:88) at org.eclipse.ui.internal.menus.TrimContributionManager.update(TrimContributionManager.java:265) at org.eclipse.ui.internal.WorkbenchWindow.updateLayoutDataForContents(WorkbenchWindow.java:3867) at org.eclipse.ui.internal.WorkbenchWindow.setLayoutDataForContents(WorkbenchWindow.java:3878) at org.eclipse.ui.internal.WorkbenchWindow.createDefaultContents(WorkbenchWindow.java:1150) at org.eclipse.ui.internal.WorkbenchWindowConfigurer.createDefaultContents(WorkbenchWindowConfigurer.java:623) at org.eclipse.ui.application.WorkbenchWindowAdvisor.createWindowContents(WorkbenchWindowAdvisor.java:300) at org.eclipse.ui.internal.WorkbenchWindow.createContents(WorkbenchWindow.java:1036) at org.eclipse.jface.window.Window.create(Window.java:431) at org.eclipse.ui.internal.Workbench$22.runWithException(Workbench.java:1211) at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31) at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35) at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135) at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757) at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803) at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1595) at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31) at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35) at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135) at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757) at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604) at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494) at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149) at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577) at org.eclipse.equinox.launcher.Main.run(Main.java:1410) at org.eclipse.equinox.launcher.Main.main(Main.java:1386) at com.arm.workbench.Hook.callOut(Hook.java:436) at com.arm.workbench.Hook.main(Hook.java:515)!ENTRY org.eclipse.core.jobs 2 2 2012-07-26 15:11:22.299!MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.ide.IDEWorkbenchActivityHelper$4
