License Feature Not Available
I am trying to connect to my android device using Device Manager from Graphics Analyzer to analyze my Unity application. I have followed the instructions on the documentation, the adb and device manager is able to detect my device, I have installed the Daemon App. However, whenever I try to connect I get an "License Feature Not Available" error. How do I fix this?
Here is my ADB Command Log:
Device: samsung SM-G900W8 (40b49871, 40b49871)
Description: Connect to the device
Result: com.arm.mgd.core.adb.IADBTask$ADBExecutionException: Could not connect to device
at com.arm.mgd.core.adb.AndroidConnector.lambda$0(AndroidConnector.java:87)
at com.arm.mgd.core.adb.AndroidConnector.lambda$2(AndroidConnector.java:155)
at com.arm.mgd.core.adb.AndroidBridgeTask.run(AndroidBridgeTask.java:51)
at com.arm.mgd.core.adb.ADBTaskManager.executeTask(ADBTaskManager.java:492)
at com.arm.mgd.core.adb.ADBTaskManager.lambda$9(ADBTaskManager.java:433)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at com.arm.mgd.core.util.executors.NamedThreadPoolExecutor.lambda$0(NamedThreadPoolExecutor.java:60)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Command 0: "C:\Users\Unknown\AppData\Local\Android\sdk\platform-tools\adb.exe" version
Exit code: 0
Output:
Android Debug Bridge version 1.0.40
Version 28.0.2-5303910
Installed as C:\Users\Unknown\AppData\Local\Android\sdk\platform-tools\adb.exe
Command 1: "C:\Users\Unknown\AppData\Local\Android\sdk\platform-tools\adb.exe" -s 40b49871 start-server
Exit code: 0
Output:
Command 2: "C:\Users\Unknown\AppData\Local\Android\sdk\platform-tools\adb.exe" devices -l
Exit code: 0
Output:
List of devices attached
40b49871 device product:kltevl model:SM_G900W8 device:kltecan transport_id:1
Command 3: "C:\Users\Unknown\AppData\Local\Android\sdk\platform-tools\adb.exe" -s 40b49871 shell am startservice -n com.arm.mgd.androidapp/.applist.DaemonLauncherService
Exit code: 0
Output:
Starting service: Intent { cmp=com.arm.mgd.androidapp/.applist.DaemonLauncherService }
Command 4: "C:\Users\Unknown\AppData\Local\Android\sdk\platform-tools\adb.exe" -s 40b49871 shell dumpsys activity services com.arm.mgd.androidapp/.applist.DaemonProxyService
Exit code: 0
Output:
ACTIVITY MANAGER SERVICES (dumpsys activity services)
User 0 active services:
* ServiceRecord{736eb43 u0 com.arm.mgd.androidapp/.applist.DaemonProxyService}
intent={cmp=com.arm.mgd.androidapp/.applist.DaemonProxyService}
packageName=com.arm.mgd.androidapp
processName=com.arm.mgd.androidapp
baseDir=/data/app/com.arm.mgd.androidapp-1/base.apk
dataDir=/data/user/0/com.arm.mgd.androidapp
app=ProcessRecord{350e42e 4142:com.arm.mgd.androidapp/u0a435}
isForeground=true foregroundId=1 foregroundNoti=Notification(pri=0 contentView=com.arm.mgd.androidapp/0x10900a4 vibrate=null sound=null defaults=0x0 flags=0x62 color=0x00000000 vis=PRIVATE secFlags=0x0 secPriority=0)
createTime=-4m2s881ms startingBgTimeout=--
lastActivity=-4m2s880ms restartTime=-4m2s880ms createdFromFg=true
startRequested=true delayedStop=false stopIfKilled=false callStart=true lastStartId=1
Command 5: "C:\Users\Unknown\AppData\Local\Android\sdk\platform-tools\adb.exe" devices -l
Exit code: 0
Output:
Command 6: "C:\Users\Unknown\AppData\Local\Android\sdk\platform-tools\adb.exe" forward --list
Exit code: 0
Output:
40b49871 tcp:51765 tcp:5002
40b49871 tcp:5002 tcp:5002
Command 7: "C:\Users\Unknown\AppData\Local\Android\sdk\platform-tools\adb.exe" -s 40b49871 shell setprop debug.vulkan.layers VK_LAYER_ARM_AGA:
Exit code: 0
Output:
