Hi Experts,
I could find two versions of RTX here. Even though i got an application note on porting RTX to CMSIS RTX I got few confusions with the below links.
http://www.keil.com/support/man/docs/rlarm/rlarm_ar_config_title.htm
Vs
CMSIS-RTOS RTX: Configuration of CMSIS-RTOS RTX
Which one will be preferable and latest ?
Whether the reference can be picked from both or should concentrate on one ?
Hey, use the CMSIS one!
The other one does mention RL. This is RealView Library. I don't believe you use RL-RTX so you don't want that one!
Oh well I go by cmsis.
Bit curious on usage of real view library :-)
Is RL the prior version or meant for different purpose !!
Regards,
Techguyz
Rather different purpose... Overview of the Keil Real-Time Library
As you can see on that page, Real Time library used to be separate and is now part of MDK-ARM professional.
I advised CMSIS because its benefits are much wider than helping you integrate an RTOS.
Of course, if an expert disagrees with my non-expert opinion, they should speak up!
Hello Techguyz,
you should use CMSIS-RTOS RTX. This is the latest version of RTX and is part of our ARM::CMSIS Software Pack with support for MDK Version 5. To understand the differences, we have created an application note that is basically a migration guide. You'll find that document here: Application Note 264: Migrate from RTX to CMSIS-RTOS
Kind regards,
Christopher
