Hi Experts,
In CMSIS RTX how the mutex and binary semaphore is handled ?
For example, in case of mutex is locked for some hardware peripheral drivers whether the task switch will be disabled ? or by any other means ?
Also where the binary semaphore should be used and where the mutex should be used ?
The documentation explains some aspects already:
Q: ... in case of mutex is locked ... whether the task switch will be disabled ?
A: osMutexWait contains.... While the system waits the thread that is calling this function is put into the state WAITING.
Thread states are described under Thread management. But I agree, it has room for improvements.
A Mutex is simpler (only ON/OFF) than a semaphore but the basic functionality is identical. Semaphores can counting (binary is with count=1) and be released from IRQ which is not possible for a Mutex.
I hope this clarifies your questions.
Hi Reinhard,
Thanks for the reply.
Consider thread A is having higher priority and thread B is having least priority. Now thread B is executing and locks the mutex for a peripheral driver. Now the interrupt occurs which triggers thread A and due to preemptive nature thread A activates. Now when thread A is trying to access the same mutex locked peripheral driver of thread B then thread A will be put into waiting state.
This is my understanding from your answer. Correct me if I am wrong.
Regards,
Techguyz
Yes, that is correct.
Note that CMSIS RTOS RTX also implements Priority Inversion. Refer to the documentation ..\CMSIS/RTOS/RTX/Doc/_theory.html#PriorityInversion
Yeah thats what I exactly want to ensure. Its priority inversion
Thanks for your valuable time.
