I find a way to program the NXP LPCXpresso 1115, following the instructions of these links
LPC link with KEIL | www.LPCware.com
CommandLineFlashProgramming - ** Code Red Support Site **
Anyone who knows how to do Flash Programming and Debugging without line commands and without and external programmer?
Hello Julio,
It is correct that the LPC-Link1 debug interface does not support Keil's debugger. There are two choices available when you want to use Keil tools:
You can connect to LPC1115 LPCXpresso board using the uLink2/ME, for example. Just connect the debug probe to connector J5 on the LPCXpresso board.
I have this working on my own bench with the following basic settings: Device/Target = LPC1115; Debug Probe = uLink2/ME; Debug Interface = SWD.
The LPC-Link2 can also connect to the LPCXpresso board at header J5. This debugger can be programmed with a CMSIS-DAP image to use with Keil tools. In uVision IDE, select "CMSIS-DAP debugger" in the Debug Settings when having the other settings same as above. See the following links for details on configuring the LPC-Link2.
LPC-Link2 | www.LPCware.com
LPC-Link 2 configuration tool | www.LPCware.com
LPC-Link 2 Configuration tool | www.LPCware.com
-arw
The problem is that the LPCXpresso 1115 has LPC Link 1 and doesn't supported by Keil, i read that LPC Link 2 is supported and i can't find a way to program and debug the board without an ULINK.
