how to use the armcc to compile the C ++  program in the DS-5 studio
Now I want to use armcc to compile the c++ program and I want to find a example under DS-5 studio.  I find under the DS-5 directory there is a CPP directory. There is a c++ example program for me to refer to. But after I study the makefile file, I have some question to ask for help. The first question is why the c++ program must include the "SYSROOT = ../distribution/filesystem/armv5t_mtx". The directory "lib and include" under the DS-5 directory can not meet the c++ program's need?   The c++ program need the  lib and headfile under the SYSROOT location?  The second question is  there is a command line paramter "--arm-linux-configure-file"  and what is the paramter's function. I do not know it all.   Please tell me the answer. Thanks!
  • If you are just trying to build a simple bare-metal application, then no special options are needed. Simply call your source file a .cpp file, and the compiler will build accordingly.
    The options above are related to building a linux application with the ARM compiler. This is a deprecated feature - we would recommend using the provided gcc instead if you are doing this.
