I am compiling on an Exynos 5250-based board with Ubuntu filesystem.
gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/arm-linux-gnueabihf/4.7/lto-wrapper
Target: arm-linux-gnueabihf
Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 4.7.2-2ubuntu1' --with-bugurl=file:///usr/share/doc/gcc-4.7/README.Bugs --enable-languages=c,c++,go,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.7 --enable-shared\
--enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.7 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-lib\
stdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --disable-libitm --enable-plugin --enable-objc-gc --enable-multilib --disable-sjlj-exceptions --with-arch=armv7-a --with-fpu=vfpv3-d16 --with-float=hard --with-mode=thumb --d\
isable-werror --enable-checking=release --build=arm-linux-gnueabihf --host=arm-linux-gnueabihf --target=arm-linux-gnueabihf
Thread model: posix
gcc version 4.7.2 (Ubuntu/Linaro 4.7.2-2ubuntu1)
Hi Chris,
I've been pointed to this fairly detailed thread: http://comments.gmane.org/gmane.linux.ports.arm.general/9544
Hopefully that should explain it, here's an extract from that thread:
GCC will reference it if you have a 64-bit divide or modulus. IOW: unsigned long long divide_by_10(unsigned long long a) { return a / 10; } will reference a 64-bit by 64-bit divide. However, we can do a lot better in the kernel: unsigned long long divide_by_10(unsigned long long a) { do_div(a, 10); return a; } which will do a 64-bit by 32-bit divide - which is what virtually all cases really want to be doing.
return a / 10;
do_div(a, 10);
return a;
Hope this helps,
Joe
