Using DCD to create a "global variable"
Hi All,
Please bear with me, I'm new to ARM/Assembly and just trying to get to grips with how to use it.
I have a jump table currently set-up like this
ProcTable
DCD Proc1
DCD Proc2
DCD Proc3
EndTable
Another part of my program that is acting as a processes manager which needs to keep track of the number of the process so it can calculate a stack pointer (PSP) for it so that each program has it's only section of the stack. I'm trying to use some sort of 'global variable' like this
"ProcCount DCD 0"
I then want to increment the value stored in ProcCount although I'm having trouble getting this to work, most examples I can find involve reading the value of ProcCount but never writing/updating the other way. I was trying to do something like this:
LDR r2,=ProcCount
ADD r4,r4,#1
STR r4, [r2]
NOP
LDR r5,ProcCount
NOP
I'm trying to add #1 to ProcCount then reading it back into r5 to check that it has changed (Nothing changes r5 stays at 0x0)
Any advice would be much appreciated!
  • If the DCD is defined in the code section, then it is likely that the value resides in read-only memory. You need to ensure that the global variable is in an area that the linker places in RAM, for example:
    ; // Code located in flash/ROM code section
            AREA ||.text||, CODE, READONLY
            EXPORT main
    ; // Read value of "global_value" into R0
    get_global_value PROC
            LDR  r1,=global_value
            LDR  r0,[r1]
            BX   lr
            ENDP
    ; // Set value of "global_value" to that in R0
    set_global_value PROC
            STR  r0,[r1]
            BX   lr
            ENDP
    ; // Simple main loop that just gets, increments and sets
    main
            BL   get_global_value
            ADDS r0,r0,#1
            BL   set_global_value
            B    main
            ALIGN
            LTORG
    ; // Global variable located in RAM data section
            AREA ||.data||, DATA
    global_value DCD 0
            END
    hth
    Simon.
